Thread: Need some help with some vacuum lines.
Results 1 to 3 of 3
  1. #1 Need some help with some vacuum lines.
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Ok guys so here is the story. I did a engine swap and car runs fine but I kept getting a p0410 code it's the secondary air injection system. Pump turns on fine as it should. Car runs fine. So I deleted the code completely from ever turning on since I saw no issue with the car. Then I saw this. As far as I am concerned it goes into the elbow right by the intake and lim. But I see nowhere to connect it too. Any help is appreciated fellas want to sell the car soon without any issues. As I said car runs fine but would like to sell it doing it right.
    Here is a pic.
    you can sell the small hose coming out all the way on to the left side of the picture, but with nothing on it or anywhere to go to.
    Thoughts?
    If You Cant Hear The Whine You're Too Far Behind...
  2. #2 Re: Need some help with some vacuum lines.
    Does it run down the firewall on the passenger side on the engine bay??
    Might be for HVAC controls???
  3. #3 Re: Need some help with some vacuum lines.
    Buena Park Ca
    The one connected to the elbow is the one that runs on the firewall all around to where the battery is.
    But look to the left by the solenoid and there is the hose I am speaking of
  1. Vacuum Lines
    By eshina17 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2014, 02:12 PM
  2. Vacuum Lines and what not
    By NewBoost1997 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-07-2012, 04:20 PM
  3. vacuum lines
    By noreasonwhyy in forum Wanted To Buy - Parts
    Last Post: 02-12-2012, 02:34 PM
  4. vacuum lines
    By Danbo004 in forum General Tech Discussion
    Last Post: 04-15-2011, 10:51 PM
  5. Different Vacuum Lines...
    By Iron Indian in forum General Tech Discussion
    Last Post: 08-17-2009, 12:47 AM
