Thread: High Output Alternator
Results 1 to 8 of 8
  1. #1 High Output Alternator
    SE Level Member KitRae's Avatar
    Jul 2012
    St. Catharines
    I work security at night and wonder when i replace my failing alternator. Would this be a good one to get as i run the battery often. Any advice would be appreciated.
    http://www.amazon.com/gp/aw/d/B008R2UES6
    Sent from my GT-S5690M
    2002 Grand Prix GT 3.8L Naturally Aspirated
    - NGK Iridium Performance Spark Plugs
    - NGK 51031 Performance Spark Plug Wires
    - EPR Cross Drilled Performance Brakes & Ceramic Pads
  2. #2 Re: High Output Alternator
    Jul 2012
    Chicago
    Not sure if you really need anything more than stock...
    -Carl
  3. #3 Re: High Output Alternator
    Stock should be fine don't think you need a high output alternator. If anything do the big 3 upgrade.Want to save some money just have your current one rebuilt.
    04 Comp G.
  4. #4 Re: High Output Alternator
    Jul 2012
    St. Catharines
    Ok. Was just thinking cause I use the battery alot.
  5. #5 Re: High Output Alternator
    That's what the alternators for to charge the battery so yea stock will be fine!
    04 Comp G.
  6. #6 Re: High Output Alternator
    Pennsylvania, USA
    Unless you run high power accessories like me (1400 watts RMS for subs alone), then no need for HO alternator.
    If you insist on one, I have one from DC power that's been golden for the past two years, 110A idle, 270A max. Iraggi is another good brand. Don't chance off brand ones off of Amazon or eBay, they normally just use under drive pulleys to boost output, and thus burn out within a year or two. You need to spend real money for a quality HO alternator that will last more than a year or two.
  7. #7 Re: High Output Alternator
    Jul 2012
    St. Catharines
    Ok. Thanks for the input all. Ill see what we do. Wife wants a good system as she is the music buff. Lol
  8. #8 Re: High Output Alternator
    GTP Level Member
    Pittsburgh
    I just got a Mechman 320A alt for my upcoming Audio build. Its expensive, but will give you all the power you need. They Also have a 270 Version
    2003 SSEi,
  1. high output alternator for 97 gtp
    By blakgtp in forum Audio, Security & Visual Electronics
    Last Post: 04-21-2013, 02:04 AM
  2. High output alternator vs battery
    By deathjunior in forum Audio, Security & Visual Electronics
    Last Post: 01-05-2011, 11:14 PM
  3. Alternator output
    By Dohner in forum Audio, Security & Visual Electronics
    Last Post: 03-31-2009, 11:25 PM
