Thread: Alternator output
Results 1 to 15 of 15
  1. #1 Alternator output
    GT Level Member Dohner's Avatar
    Montpelier
    With my system on and playing the lights dim and you can feel the car hesitate due to the power loss when the bass hits. I have seen those like piggy back wires you plug into the back of the alternator. I was wondering if those things actually work.
  2. #2 Re: Alternator output
    SE Level Member Orbital431's Avatar
    Albuquerque, NM
    this happened to me when i got my system (2x 15" speakerz and a 700watt amp, not too big).
    in most cases, a higher output battery, and if u wanted, a new OEM (if not higher output) alternator is all u need. solved my problem and that was over a year ago
  3. #3 Re: Alternator output
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    I would start by upgrading the alternator to battery wire, and making sure that all of your power wiring is in top shape.
    http://www.grandprixforums.net/f81/a...nk-s-3304.html
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  4. #4 Re: Alternator output
    Saraland Alabama
    upgrade the wiring, a battery does not help once the car is running, if still dimming, you need an upgraded alternator
  5. #5 Re: Alternator output
    Montpelier
    That is what i thougth i would hear. What is the next size up that i would need anyone know.
  6. #6 Re: Alternator output
    Saraland Alabama
    I use a minimum of 2 gauge wiring for power and ground, the system is only going to carry what your main power can deliver
  7. #7 Re: Alternator output
    Montpelier
    THat is the size wire i run also it gives it enough power it just pulls it out of the car real bad. I will have to see about getting a bigger alt. Thanks for all you input.
  8. #8 Re: Alternator output
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    The 04+ alternator is a 125amp unit and is a drop in replacement. Not a lot bigger but you should be able to get one cheap enough.
  9. #9 Re: Alternator output
  10. #10 Re: Alternator output
    Montpelier
    Thanks man so if i just go to the auto store i can get one for an 04 and it will work on my 02.
  11. #11 Re: Alternator output
    Las Cruces, NM
    Yes, Im not sure if the aftermarket ones are 125A, but they should be.
  12. #12 Re: Alternator output
    Albuquerque, NM
    a lot of the aftermarket one's i've found have had a higher output than OEM and stuffs. hopefully u'll find a lot of those too.
  13. #13 Re: Alternator output
    Thunder bay,Ontario.Canada
    If you want to stop the dimming and save your electrical system, you'll take with your audio supplier or installer about the proper value stiffening capacitor for your sound system. Whats hapening is your amp takes so much power from your battery that it causes your alternator to surge. The stiffening capacitor charges and discharges to keep your amp input voltage at its maximum resulting tighter harder and lower base. well woth the couple hundred bucks for a good cap. soory bout the long post, hope it helps some>
  14. #14 Re: Alternator output
    GT Level Member jasonball's Avatar
    Nov 2008
    ft. mitchell
    Quote Originally Posted by MARKS99 View Post
    there is a thread about cap vs other stuff. caps are not a fix to the problem. but more of a hinder in the long run.
    if you need something that will not kill your battery, or you alt. look into a batcap 800 or 2000. google it. worth the time reading. Caps are worthless.
  15. #15 Re: Alternator output
    Montpelier
    Quote Originally Posted by jasonball View Post
    I did have a cap in the car and yeah the lights were not going as dim but still didnt fix the problem. I have not done anything yet i figure i will get a diff. alt when this one takes a crap on me.
  1. Removing alternator housing
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-06-2010, 06:14 PM
  2. Where is the OBD output?
    By HOPPY in forum General Tech Discussion
    Last Post: 07-08-2008, 10:10 AM
  3. Q? Output Shaft removal
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-22-2008, 09:07 AM
  4. Effect Of NightShade On Light Output
    By SyntheticShield in forum Visual/Body Modifications
    Last Post: 02-08-2008, 08:36 PM
