I use a 1/4" drive extension. Usually just a 2" one on a ratchet. It should fit right in and then just turn it counterclockwise. The plug twists out as you turn it and only comes out about a half an inch and then the coolant should start flowing out from under the radiator. It does not drain out at the plug but below it, you are just opening the drain.
