Thread: Which O2 Sensor Tool?
Results 1 to 10 of 10
  1. #1 Which O2 Sensor Tool?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Guys that have removed/install a lot of O2 Sensors, what type of tool do you find the best to use? Price doesn't matter, I just want to get the easiest to use.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  2. #2 Re: Which O2 Sensor Tool?
    GTX Level Member MTXGTP's Avatar
    wamego,KS
    they make sockets that i always have thought worked well.they have a cut in the side for the wire and they fit on 1/2 drive wratchet
    Justin Young, Kansas
    1999 silver GTP DHP pcm,3" Cattless hogan DP,Front PLOG,3.4 pulley, ported TB, ported LIM, ported supercharger housing.porting done by GBP
    coming soon: LS6 springs ,1.9rr
  3. #3 Re: Which O2 Sensor Tool?
    St Louis MO
    Quote Originally Posted by MTXGTP View Post
    thanks. I wonder if they are also available in a 3/8 drive for tight spot? I guess a 7/8 open end wrench for the really tight spots would work. Probably heading up to Sears tomorrow for a socket type.
    2010 Camaro SS LS3
  4. #4 Re: Which O2 Sensor Tool?
    Oklahoma
    Ive always just disconnected the electrical connector, broke it loose with a wrench then spun them out by hand.
  5. #5 Re: Which O2 Sensor Tool?
    Barksdale AFB, LA
    Go to Autozone and ask to rent the O2 sensor set. Has everything you'll want (including offset sockets). Not much money, and you'll get every dime back when you take it back (part of their "renting" policy).
    2009 Subaru Impreza WRX STI
  6. #6 Re: Which O2 Sensor Tool?
    St Louis MO
    Quote Originally Posted by Sabrewings View Post
    Thanks. I have a Wideband for tuning with my HPTuners. This will be an on going thing, so renting isn't an option.
    Thanks to all that replied with options and Dave (Trannyman) for your emailed advice.
    2010 Camaro SS LS3
  7. #7 Re: Which O2 Sensor Tool?
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
  8. #8 Re: Which O2 Sensor Tool?
    St Louis MO
    Quote Originally Posted by VinnieGTP View Post
    Looks like the one I picked up from O'Reilleys a few minutes ago. Theirs was $10 but still not too bad.
    2010 Camaro SS LS3
  9. #9 Re: Which O2 Sensor Tool?
    PA
    I have an O2 socket like the one posted above in 1/2". I only use it half the time because sometimes they are in tight spaces. They work well for the GP though. But maybe a 3/8" would work better.
    Anyway, the other half of the time I just use a 7/8" flare nut wrench. Works really well.
    2001 GSE
  10. #10 Re: Which O2 Sensor Tool?
    Moore, Oklahoma
    Quote Originally Posted by IndeedSS View Post
    I got one too, works great!
    Shawn W. Larsen
  1. Tool Definitions
    By Abrasive in forum Off Topic Discussion
    Last Post: 01-31-2012, 04:14 PM
  2. ambient air temp sensor
    By Toasty in forum General Tech Discussion
    Last Post: 09-10-2011, 10:12 PM
  3. ATTN Farnsworth - tool info needed
    By IndeedSS in forum General Tech Discussion
    Last Post: 03-14-2008, 10:54 AM
  4. KR/scan tool
    By ldyzluvdis06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2008, 10:24 PM
  5. New CHEAP upgrade MAF sensor!!!!
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 12-27-2007, 12:56 AM
