Thread: HV3 insert installation help
Results 21 to 40 of 67
  1. #1 Re: HV3 insert installation help
    Dec 2011
    Philadelphia, PA
    ZZP's page claims 9 WHP peak and 30 WHP at 6000 rpm.
    This test vehicle had ER rockers, 180 * stat and some other thing i can't recall.
    ah ok guess ER rockers are comming sooner then i thought then
    AEM bruteforce intake
    Diablo 93 Octane tune
  2. #2 Re: HV3 insert installation help
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    read the whole thing, the 15 whp power is 6000+rpms. like i said you need a tune so you can atleast rev higher.
    but drive it for while, your pcm need to adapt the best it can for the extra air. I had a tune already before i got the hv3, i got the hv3 and went got a retune and overkill said i was running lean so he added extra fuel and timing io noticed a good jump after he was done, just keeps pulling harder now.
    thats even after my first tune....so thats why i say TUNE TUNE TUNE makes or breaks the hc3 experience.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  3. #3 Re: HV3 insert installation help
    Dec 2011
    Philadelphia, PA
    Quote Originally Posted by Grimsin View Post
    very very true, i was just gonna wait on tune untill i add everything else so im not wasting money on 2 tunes
  4. #4 Re: HV3 insert installation help
    St Thomas Ontario
    IM not a mechanic. all i know is what overkill told me when i got my first tune(just cai and u-bend delete & 91 octane tune dont know if that makes a difference) that when i get a hv3 to get a retune, that he would get more power.
    so i did that just yesterday, he drove it for a bit, pulled over, said i was running lean so he added fuel and some timing, took a run, did it again,added mroe fuel & timing, took a run, did it again. then he changed some part throttle fuel trims and i was done, and i can honestly say pulls alot better now then it did before the retune.
    Ask overkill as i dont know im just going by what he did/said.
  5. #5 Re: HV3 insert installation help
    Dec 2011
    Philadelphia, PA
    will do, thanks dude, overkill is wat ill be leaning toward anyway
  6. #6 Re: HV3 insert installation help
    Dec 2011
    Philadelphia, PA
    i think i def lost power overall by installing this, ******* i shoulda waited to put that in
  7. #7 Re: HV3 insert installation help
    GT Level Member SoergBot's Avatar
    Oct 2011
    Dayton
    Quote Originally Posted by sLpGPGT View Post
    low-end?
  8. #8 Re: HV3 insert installation help
    Dec 2011
    Philadelphia, PA
    Quote Originally Posted by SoergBot View Post
    low-end?
    low end and i cant feel any difference top end, i did put 92 gas in and it felt little faster but i honestly cant feel much difference
  9. #9 Re: HV3 insert installation help
    remove it and see if you still think you lost power?
  10. #10 Re: HV3 insert installation help
    Dec 2011
    Philadelphia, PA
    haha i rather not do that again for a while, the fuel injectors were a absolute pain in the ASS to get off and on but ill still give it a chance maybe the pcm has to get used to the different air flow like previously stated above
  11. #11 Re: HV3 insert installation help
    Now that they're been freshly removed, they should come out very easily.
    I can't see how the HV3 would affect your MAF calibration which is what determines your fueling.
    It would greatly affect VE which supposedly isn't referenced for anything but MAF failure.
  12. #12 Re: HV3 insert installation help
    Kansas
    I never really felt a huge gain stock with just the HV3 in it. Headers is what I felt the most difference. And like Matt stated, 1-3/4" primaries do seem to make a big impact on low end. But top end it eats.
  13. #13 Re: HV3 insert installation help
    Dec 2011
    Philadelphia, PA
    Quote Originally Posted by NegativeOne13 View Post
    i never felt any gain haha, and yea headers will be the next thing ill add on, most likely good old SD headers
  14. #14 Re: HV3 insert installation help
    St Thomas Ontario
    all the extra power is at the high rpms, instead of losing tons of power after 5000 rpms it keeps the power going untill 6000-6200 rpms THEN falls on its face lol.
    if you were expecting more power across the board then you didnt read what it does correctly.
    exactly why i didnt buy the hv3, instead was given to me as a gift lols.
  15. #15 Re: HV3 insert installation help
    You put in 92 and made it feel faster with the HV3 because it was probably knocking and yanking timing out and the higher octane killed it.
    Yay, N/A knocking800.
    To add, If I keep this silver car, I'll be hitting the dyno before and after I do a few things...
    As it sits now, just an L26 top end with no runners at all, intake, ported TB, tune...and uhhh, a catback/180*.
    So, maybe 170 WHP.
    I'm looking for 220 with the heads/LIM/cam/WB tune...etc.
  16. #16 Re: HV3 insert installation help
    St Thomas Ontario
    bluegtp91 is correct, i was incar tuned from overkill on 91 octane just with cai and ubend delete. when i got my hv3 and downpipe I got retune and overkill said i was running lean.
    needsatunedude
  17. #17 Re: HV3 insert installation help
    How does that change your maf calibration?
    It suggests your MAF calibration was incorrect or the fuel settings are incorrect.
  18. #18 Re: HV3 insert installation help
    Florida
    Thats weird that you didnt notice any gain although it takes me a day or two before i notice any gains from my mods. I would say unplug your battery overnight and try it the next day. Speaking of dyno and N/A im gonna hit the dyno soon since i got an overkill tune now and see what i put out.
    Ohio
    I'll say it once like I've said before......
    It's all in the tune... Bruhz
  20. #20 Re: HV3 insert installation help
    Dec 2011
    Philadelphia, PA
    ill try unplugging my battery and plug it back in and see wat that does but i doubt anything will happen, ^^^ and i agree but as i said i waiting till i get the tune after i put few other things in the car so i dont have to tune twice, and yea dude i felt absolutly nothing except for longer power in 6k-6200, i knew i shoulda waited till after i did everything, but oh well
  1. ZZP HV3 Insert?
    By ray4was in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-04-2011, 01:04 PM
  2. Upper Insert Installation
    By muffinman991 in forum General Tech Discussion
    Last Post: 10-03-2010, 08:00 PM
  3. HV insert
    By MBruneaux in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-18-2010, 05:00 PM
