Thread: 2004 Grand Prix using oil
Results 1 to 15 of 15
  1. #1 2004 Grand Prix using oil
    Sep 2011
    Hi everyone,
    I have a 2004 Grand Prix, non supercharged, that seems to be using oil. I have looked all over and cannot find a "drip" or a leak. The intake gaskets were just replaced less than 500 miles ago by the dealer. There is no smoke or soot on the tail pipes. Don't know where to look next. Dealer says it should be no part of the intake gasket process. There is 78,000 miles and it runs very well. The oil has dropped 2 holes from the very top hole on the dipstick since then. Ant thoughts?
    Thanks you!
  2. #2 Re: 2004 Grand Prix using oil
    maybe plugged PCV valve causing extra oil comsumption?
  3. #3 Re: 2004 Grand Prix using oil
    GTX Level Member cerick08GP's Avatar
    Sounds to me like it is pretty early in the game to think your car is “using” oil. A couple ticks on the dip stick could mean nothing at all. I’d just keep checking it and see if an actual trend develops.
    x2 on the PCV valve, they are so cheap and easy to replace I’d just do it. Interesting enough I thought my car starting using oil this summer. I was freaking because I have never observed any oil usage/oil level drop before. Long story short I’m 99% sure it was my choice in motor oil. I have been pouncing around oil brands lately, and I’m pretty sure about a quart just plain got consumed over about 3k mile. After my last oil change the trend hasn’t repeated.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  4. #4 Re: 2004 Grand Prix using oil
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    My 06 did the same and my moms 08 does too. No clue where it goes either.
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  5. #5 Re: 2004 Grand Prix using oil
    Sep 2011
    Thanks for the reply's, I have already changed the PCV valve, no change in the "consumption". I am just monitoring it as it has not happened in the past. Just was curious if there was something with these engines as I have not owned a GM product long term before.
  6. #6 Re: 2004 Grand Prix using oil
    Omaha, NE
    What kind of oil are you using? Is it different from what was previously used?
  7. #7 Re: 2004 Grand Prix using oil
    Sep 2011
    Oil is the same, dealer changed since new. They are telling me that it is "normal" but I have never had a car of any brand (in almost 40 years of driving) that has used oil. I have had a few that dripped, but you always knew where the oil was going. It is frustrating for sure!
  8. #8 Re: 2004 Grand Prix using oil
    You are obviously being a bit hyper-aware of your car after the gasket change. Generally speaking what they did shouldn’t have caused an oil usage problem. That said, I don’t trust many mechanics further than I could throw them. As a rule of thumb, more than a quart every 1k miles points toward a real problem. You need to track long term the actual oil usage, not dip stick holes over arbitrary distances. If you go around telling mechanics your two holes over 500 miles there are going to just shake their heads. Also be aware that the best engines do and should use some amount of oil that said I have been driving GPs for 10 years now with basically never having to add oil between changes.
    If you want to actually do something I’d start by inspecting your spark plugs. If there is one that is black or has goo on it, you might have a problem in that cylinder. The most common oil usage in these engines is the valve stem seals, or you could be very unlucky and have a piston ring issue. Our engines (besides the whole intake gasket thing) are generally rock solid, the only issues tend to be what people do to them with mods and such.
    On a side note, dealerships tend to use the cheapest oil and filters they can possibly buy. Some have even been caught not even using oil that is approved by the OEM specs. Granted oil these days is so much better than in years past even the cheapest oil tends to do the job. More over some times those shop monkeys don’t flipping know what oil is going into your car even when you ask them. Do your self a favor and take your car to an oil change place (the locally owned ones tend to be best) where you can actually have a good name brand oil put in. I would recommend brand name “high mileage” oil. High mileage oil has more additives that help prevent oil usage, and more importantly extra seal conditioners to plumb up those valve seals a bit.
    2008GP
    2002GP||sold
  9. #9 Re: 2004 Grand Prix using oil
    GT Level Member SoergBot's Avatar
    Oct 2011
    Dayton
    I have that with my 08 as well, I was using 5w-30 full synthetic, and every other time i checked i was filling it up 1/4 to 1/3 of a bottle. I switched to 10w-30 and it seems to be just fine, dropped a can of sea foam in it as well.
    It may be just because your running a thinner oil, if you are, or something completely different, hope my input helps.
  10. #10 Re: 2004 Grand Prix using oil
    Sep 2011
    Thanks for all the responses... I am in the process of recording it over the next 1000-3000 miles. I put almost 800 miles a week on so it shouldn't be too long to get a trend on record. I just check the oil in the morning and have noticed the change and couldn't really find anything on this site that matched the circumstances. I will "re-think" my process of oil changes, thanks!
  11. #11 Re: 2004 Grand Prix using oil
    every car ive ever owned with 100,000 miles or more has always burned a quart or oil before 3,000 miles on a oil change. just the way it is.
  12. #12 Re: 2004 Grand Prix using oil
    GM considers it normal, probably because of the Tech bulletin about it. They expect that 1 quart every 3K miles is "normal". I don't measure oil in my cars...but I'd say that's likely about right.
  13. #13 Re: 2004 Grand Prix using oil
    New Jersey
    My 06 uses a little oil, in fact to be honest I have never owned an internal combustion engine that did not burn a little oil over time. Sure, some use more than others but I consider anything less then a quart in 1000 miles to be acceptable.
    On a new car I'd be pissed of course but at 100,000 miles a quart in 3K is more than acceptable in my book
    I run 0w30 Mobil 1 in my GP and 0w20 in my wifes Honda powered vue. The Honda 3.5 with almost 90K on it burns around 1/4 of a quart in 8000 miles. The GP with the 3.8 at 44,000 miles around half a quart in 3000 miles or so.
    Also, adding a 1/4 of a quart every time you check it is just a bit much for me. The engine tolerates a range of 1 quart. That means if your near the bottom of the range, or top it doesn't matter. I don't add until I'm a quart low unless I'm going on some long trip and assume I may dip below the minimal level. Same goes with my ATVs, I add when I'm approaching the bottom of the operating range on the stick. For some reason a lot of guys think it has to be to the top of the dipstick. In my opinion the "best" spot is dead center of the operating range.
  14. #14 Re: 2004 Grand Prix using oil
    i never top of my oil till its a quart low too. who wants 1/2 quarts of oil laying around?
    from what i understand, engines make more power when a quart low too.
    i think it was Edwards in nascar last year had a missing oil cap allowing oil to escape from the engine. i think they got a fine and some pts taken.
  15. #15 Re: 2004 Grand Prix using oil
    New Jersey
    On our engines I'm sure they technically make more power a quart or even two quarts low. The poor crank is sloshing through the stuff.
    Now on a dry sump setup its probably a different story.
  1. 2004 Grand Prix GT1
    By slopez in forum Members Rides
    Last Post: 03-15-2011, 12:11 PM
  2. 2004 pontiac grand grand prix gtp
    By jeffreytatro606 in forum Introductions/Noob Questions
    Last Post: 02-03-2011, 06:23 PM
  3. just got a 2004 Grand Prix
    By bjornbjorn in forum Introductions/Noob Questions
    Last Post: 07-09-2010, 05:22 PM
  4. 2004 Grand Prix HUD
    By l3enner in forum Audio, Security & Visual Electronics
    Last Post: 07-14-2009, 03:04 PM
