Thread: 2004 Grand Prix using oil
Results 1 to 15 of 15
  1. #1 Re: 2004 Grand Prix using oil
    New Jersey
    My 06 uses a little oil, in fact to be honest I have never owned an internal combustion engine that did not burn a little oil over time. Sure, some use more than others but I consider anything less then a quart in 1000 miles to be acceptable.
    On a new car I'd be pissed of course but at 100,000 miles a quart in 3K is more than acceptable in my book
    I run 0w30 Mobil 1 in my GP and 0w20 in my wifes Honda powered vue. The Honda 3.5 with almost 90K on it burns around 1/4 of a quart in 8000 miles. The GP with the 3.8 at 44,000 miles around half a quart in 3000 miles or so.
    Also, adding a 1/4 of a quart every time you check it is just a bit much for me. The engine tolerates a range of 1 quart. That means if your near the bottom of the range, or top it doesn't matter. I don't add until I'm a quart low unless I'm going on some long trip and assume I may dip below the minimal level. Same goes with my ATVs, I add when I'm approaching the bottom of the operating range on the stick. For some reason a lot of guys think it has to be to the top of the dipstick. In my opinion the "best" spot is dead center of the operating range.
  2. #2 Re: 2004 Grand Prix using oil
    i never top of my oil till its a quart low too. who wants 1/2 quarts of oil laying around?
    from what i understand, engines make more power when a quart low too.
    i think it was Edwards in nascar last year had a missing oil cap allowing oil to escape from the engine. i think they got a fine and some pts taken.
  3. #3 Re: 2004 Grand Prix using oil
    New Jersey
    On our engines I'm sure they technically make more power a quart or even two quarts low. The poor crank is sloshing through the stuff.
    Now on a dry sump setup its probably a different story.
  1. 2004 Grand Prix GT1
    By slopez in forum Members Rides
    Last Post: 03-15-2011, 12:11 PM
  2. 2004 pontiac grand grand prix gtp
    By jeffreytatro606 in forum Introductions/Noob Questions
    Last Post: 02-03-2011, 06:23 PM
  3. just got a 2004 Grand Prix
    By bjornbjorn in forum Introductions/Noob Questions
    Last Post: 07-09-2010, 05:22 PM
  4. 2004 Grand Prix HUD
    By l3enner in forum Audio, Security & Visual Electronics
    Last Post: 07-14-2009, 03:04 PM
