Thread: Engine swap questions.
Results 1 to 3 of 3
  1. #1 Engine swap questions.
    Oct 2011
    Tacoma Washington
    Over the next 2-3 weeks I am planning to pull the L36 out of my 2001 bonneville SE and drop in a top swapped l26. so far I have the l26 on an engine stand and have already installed l67 heads and l32 intake. I have a gen v m90 with l67 tb adapter and l67 tb I am planning to put on once the engine is installed in the car. I will also be installing speeddaddy headers and making my own fenderwell intake at the same time. I had a few questions I am having trouble answering on my own.
    1. I was planning to install valve seals when I had the heads off and forgot. Is it possible to install them with the heads on the engine and if so does anyone have a link to a writeup?
    2. I'd like to have my pcv function as close to stock as possible (perferably without a breather) I had a link to how to do this but can't find it. Could someone lay that out for me or link me to a a writeup.
    3 I'd also like my egr to function as close to stock as possible. Whats the best way to do this? Will I need any of the egr blockoff plates from zzp to make the top swap work?
    4. I wont be buying a tuner until probably after tax time next year. For now I have a zzp top swap pcm. It is tuned for my l36 map sensor. From reading on forums it looks like some people hook it to up to the outlet below the supercharger snout and others on the l67 tb. What is the best way to do it?
    Any tips to make a engine swap easier are welcome. So far I have just followed the steps to removing the engine in my chilton guide and will probably disconnect the transmission and pull the engine tomorrow or the next day depending on weather.
    Only major mistake I've made so far is twisting off a piece of the starter when trying to disconnect the red and green wires from it. Gonna call Ed Morad parts on monday and see if I can get a used one.
    2001 silver Pontiac Bonneville
  2. #2 Re: Engine swap questions.
    valve seals can still be done. you'll want an air compressor and an adapter to fill the cylinders with compressed air, remove rockers (if you've already installed them) and use a valve spring compressor to remove the valve springs and you're there.
    PCV should work granted you get the pluming right on the external side of the blower. Hose from nipple on back goes before throttle plate, after MAF IIRC.
    EGR will work just as it did before. bolt into the same location and all.
    TB outlet is fine for an L36 MAP.
  3. #3 Re: Engine swap questions.
    Florida
    You can change valve seals wih the valves still in?
    Also not sure id your car is lowered but the SD headers get low and if u lower it they will be very low from what I have read. Might want to follow the writeup to have it fixed if u have the time and money
  1. a few top swap questions
    By The Wolf in forum General Tech Discussion
    Last Post: 09-07-2011, 11:52 PM
  2. engine swap 3800 sc to same but not burned engine
    By roger7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 01:59 PM
  3. engine swap questions
    By chrisgsx in forum General Tech Discussion
    Last Post: 02-19-2011, 01:21 PM
  4. Top swap questions
    By killer84 in forum General Tech Discussion
    Last Post: 12-17-2010, 08:28 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
