Thread: What do I need to change?
Results 1 to 15 of 15
  1. #1 What do I need to change?
    Never Never Land
    I'm picking up a (nother) motor for the Camaro in a few weeks. What do I need to change over for it to work?
    I already know i have to change the upper intake and rails. What about the exhaust manifolds? Also, I believe the power steering and the a/c compressor are on opposite sides. Can they just be swapped over?
  2. #2 Re: What do I need to change?
    Charles City, IA
    yeah exhaust manifolds, the block should be tapped for the different mounting locations.
    SMGPFC Two Nipple General
  3. #3 Re: What do I need to change?
    Never Never Land
    What about EGR?
  4. #4 Re: What do I need to change?
    Charles City, IA
    use the f body lim. Pretty much just use the long block and swap everything else.
  5. #5 Re: What do I need to change?
    Never Never Land
    i thought the LIM was the same
  6. #6 Re: What do I need to change?
    Charles City, IA
    Looking at a google pic of the fbody 3800 they are diff, because the fwd lim has the egr port and t stat housing.
  7. #7 Re: What do I need to change?
    Charles City, IA
    front cover is also diff.
  8. #8 Re: What do I need to change?
    Never Never Land
    now that you mention i do remember the thermo in the upper intake
  9. #9 Re: What do I need to change?
    Never Never Land
    front cover? like the timing chain cover?
  10. #10 Re: What do I need to change?
    Charles City, IA
    never mind, the oil filter adapter is just diff.
  11. #11 Re: What do I need to change?
    Charles City, IA
    you will see the differneces when you get it home.
  12. #12 Re: What do I need to change?
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    the oil filter mount thing idk wat its called but its dffrent
  13. #13 Re: What do I need to change?
    Never Never Land
    Pretty sure the oil filter after will work cuz I remember someone talking about using one their Camaro to make oil changes easier on fullthrottlev6.com
    Since Im going to have to change the Lower intake gasket which do you guys recommend I'd probably only put 25,000 miles or less on it till I turbo it (hopefully lol) so I wouldn't mind getting the cheaper lesser quality one since I wont run it that long
  14. #14 Re: What do I need to change?
    GT Level Member MrPhotographer06's Avatar
    Fort Bragg, NC
    getting cheeper/less quality one for now... sounds like a bad sentence in itself. good luck!
    2001 Grand Prix GT
    3800,Open Cone, Tinted tails, 5% front tint, double 5% rears. Kenwood head unit, new subs-pending
  15. #15 Re: What do I need to change?
    Never Never Land
    well im just saying why buy the expensive one when its just gonna be ripped off in 25K or less? I'm not gonna get anything out of buying the better one so it would be more or less wasting my money.
  1. Change oil at what %?
    By shawnz90 in forum General Tech Discussion
    Last Post: 07-25-2011, 09:04 AM
  2. oil change
    By Will5600 in forum General Tech Discussion
    Last Post: 10-25-2009, 09:54 PM
  3. What should I change?
    By atruebudfan in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-12-2009, 02:13 PM
  4. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
  5. s/c oil change
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-10-2008, 05:44 PM
