Thread: Unplugging injector wires?
Results 1 to 4 of 4
  1. #1 Unplugging injector wires?
    Dec 2008
    Indianapolis, IN
    I've never had to do it on a GM vehicle -- the plugs have this little blue clip in the middle. How do we get them off?
  2. #2 Re: Unplugging injector wires?
    Feb 2010
    Connecticut
    Its simple, there is a metal clip roughly in the shape of a U that you have to push. When you push the clip you will see the sides of the clip move out and then the clip pulls off at the angle it attaches to the injector. The metal clips are not perfect and sometimes get stuck. A few of mine were stubborn and the metal clips took a decent amount of force to compress. Be careful if you break a injector you'll have to remove the fuel rail and install a new one. Dealer price $155 each.
  3. #3 Re: Unplugging injector wires?
    Dec 2008
    Indianapolis, IN
    No -- I'm talking about the electrical control wires, not the injectors themselves.
  4. #4 Re: Unplugging injector wires?
    GT Level Member shawn3091's Avatar
    Jan 2009
    State College PA
    Quote Originally Posted by Teancum View Post
    if you look at it you should be able to see the other end of the blue clip, sqeeeze it with fingers or needle nose and pull it out, then you just unclip it and pull the plug out
  1. Injector ?
    By CrazyGuy03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2010, 10:43 PM
  2. Replacing Injector
    By TCO in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-10-2009, 05:12 PM
  3. 99% Injector duty
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2008, 11:13 PM
  4. Injector cleaning, yes or no?
    By Sabrewings in forum General Tech Discussion
    Last Post: 10-20-2008, 12:17 AM
  5. unplugging pcm
    By nemesis in forum PCM Tuning
    Last Post: 03-06-2008, 02:37 AM
