Thread: Ticking/Clattering Noises
Results 1 to 3 of 3
Threaded View
  1. #1 Ticking/Clattering Noises
    SE Level Member FlaminWhite97GTP's Avatar
    Nov 2009
    Monee, IL
    I have a light clattering noise between 1k & 2k Rpms. You dont hear it under 1K & over 2k. When I lightly push the throttle & the RPMS holds in between that range is you hear it. If I rev it up with more throttle you dont hear it between the RPM Range, but when the RPMs drop you hear it in the 1-2k range. It sounds like it's coming from the rear of the engine. You can barely hear it in the car & once the engine get up to operating temp it goes away. So IDK if it lifters, detonation or what. Its weird. I will get a video later of it. It was doing it when I first got the car 2 months ago, and it did it after my oil change. It also seem like it got louder when my mom put 87 in my car (which I NEVER do). So any help would be apprecitated.
    176K Miles, Things Done: 25K Tranny, VC & LIM Gaskets Replaced, synthetic fluids all around.
    Mods to come: CAI, Headers, Roller Rockers, U-bend & DP Delete, etc
  1. squeaking nose from steering
    By 2000GTP in forum Brakes/Suspension/Chassis
    Last Post: 01-19-2010, 08:09 AM
  2. Clattering Under Heavy Accel
    By BuyMyWheels in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-11-2009, 10:39 PM
  3. trac light on; rpms zero no power
    By skeen01 in forum Introductions/Noob Questions
    Last Post: 06-25-2009, 01:43 AM
  4. RPMs stuck at 4000 with check engine light
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2008, 12:25 AM
