Thread: Replacing Injector
Results 1 to 19 of 19
  1. #1 Replacing Injector
    I was wondering how much work it is to change a fuel injector on cylinder 5. What do I all need to take off to get to the injector?
    Thanks
  2. #2 Re: Replacing Injector
    Charles City, IA
    Take the fuel rail off. Pull the clip that holds it on the rail. Then it will pull off the rail.
    SMGPFC Two Nipple General
  3. #3 Re: Replacing Injector
    May 2008
    staten island,NY
    make sure you change all of the orings while its out. dont forget to use either o-ring grease or vasoline to lube them before you put them back into the intake manifold and the rail
  4. #4 Re: Replacing Injector
    Serious question, why do parts stores say this car needs 12 o-rings?
  5. #5 Re: Replacing Injector
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    because i think it does.. lol
  6. #6 Re: Replacing Injector
    Medford, NY
    the lower and upper orings
  7. #7 Re: Replacing Injector
    Ah, "if the first one ****s up or doesnt fit because we're so incompitent, theres another one!"
  8. #8 Re: Replacing Injector
    Medford, NY
    lol no do not **** any of them up.. you need all 12.. or you will have to buy a new set.. one oring goes in the fuel rail.. the other in the engine.. kinda lol
  9. #9 Re: Replacing Injector
    You missed the joke.
    Simply put, it seems overkill to have two injector o rings. That is all.
    The design probably requires it, but that would be an interesting design now wouldnt it.
  10. #10 Re: Replacing Injector
    Donating Users blowfishRus6's Avatar
    g.a.
    as bio would say, make sure you spit on them a little.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  11. #11 Re: Replacing Injector
    Quote Originally Posted by blowfishRus6 View Post
    LOL so thats where that came from.
  12. #12 Re: Replacing Injector
    g.a.
    yup
    its slow.
  13. #13 Re: Replacing Injector
    May 2008
    staten island,NY
    one for the top of the injector when it goes into the fuel cup, one for the bottom when it goes into the bung on the head or manifold. its not rocket science fellas its only a 3.8
  14. #14 Re: Replacing Injector
    Oh just wait till you have to work on a DI'd engine...
  15. #15 Re: Replacing Injector
    Donating Users kfish's Avatar
    Ohio
    yes make sure you lube them! shove them in the heads without lube and youll **** them up and have a big vacuum leak
  16. #16 Re: Replacing Injector
    Apr 2009
    stockton ca
    yea its easy as hell to do only thing i had issue with was the retaners they were a b1tch to get clipped
  17. #17 Re: Replacing Injector
    Ohio
    youll probably have a hard time getting your old injector out. i used some pb blaster and just kept twisting it back and forth. then it popped right out. and your new injector will come with new o rings. dont be shocked, they are about 80 bucks apiece.
  18. #18 Re: Replacing Injector
    ZZ Performance
    For twice that you can get six.
  19. #19 Re: Replacing Injector
    Well I was working last night and drove my sisters car and my dad decided to replace it himself. He said it was pretty easy. Thanks for the help guys.
  1. Replacing Injector O-ring's [*]
    By J_Ferguson in forum How To Write-Ups/Tech Tips
    Last Post: 04-25-2013, 12:48 PM
  2. 42.5# injector tables for DHP PT
    By Sabrewings in forum PCM Tuning
    Last Post: 08-18-2009, 04:44 PM
  3. injector scaler
    By impalamike3800 in forum PCM Tuning
    Last Post: 06-09-2009, 03:22 PM
  4. 99% Injector duty
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2008, 11:13 PM
  5. injector removal
    By Charged97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2008, 09:43 PM
