Thread: changing oil pan gasket
Results 1 to 8 of 8
  1. #1 changing oil pan gasket
    wi
    I think it is my pan gasket as the car leaves a little puddle of oil on the ground after a while..If it was the valve cover gaskets it should burn off correct? I haven't noticed it till I changed the LIM. Just curious if you can change the pan gasket with the engine still in the car?
  2. #2 Re: changing oil pan gasket
    memphis
    It still could be tha valve cover..some of tha oil may burn off, but they still will leave a spot on tha grond....
  3. #3 Re: changing oil pan gasket
    GTP Level Member Scimmia's Avatar
    QCA, IA
    And if it does end up being the oil pan gasket, you can change it in the car, but you're going to have to lower the subframe some to get clearance.
    2001 Buick Regal LS - Almost Stock
  4. #4 Re: changing oil pan gasket
    TDCRacing
    Guest
    Main seals? Not common but another possibility.
  5. #5 Re: changing oil pan gasket
    wi
    Well I changed the valve cover gaskets and it appears to still be leaking...Next oil change it'll probably come off...What do you mean lower the sub frame?
  6. #6 Re: changing oil pan gasket
    QCA, IA
    Quote Originally Posted by ratnick View Post
    I mean you can't just take the bolts off and take the pan off, there's not enough room. You need to support the engine from above and lower the engine cradle/subframe to get clearance to get it off.
  7. #7 Re: changing oil pan gasket
    Charles City, IA
    ^ yup. Still a little bit of a squeeze with the subframe dropped some.
    SMGPFC Two Nipple General
  8. #8 Re: changing oil pan gasket
    Augusta, Ga
    Do I understand that it IS possible to get the oil pan out without taking the engine out of the car. I'm trying to and I am stuck with the support brace that's bolted to the oil pan and covers one of the bolts on the oil pan. It at the front of the pan running up beside the frame and the rubber engine mount. Any suggestions?
  1. changing to a l67
    By srziemkowski in forum Off Topic Discussion
    Last Post: 02-10-2009, 09:44 PM
  2. Thinking of changing oil
    By GTP4 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-19-2008, 04:00 PM
  3. changing supercharged oil
    By nemesis in forum General Tech Discussion
    Last Post: 08-06-2008, 12:27 PM
  4. Changing headlights
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 02-26-2008, 08:56 PM
