Thread: changing oil pan gasket
Results 1 to 8 of 8
  1. #1 Re: changing oil pan gasket
    TDCRacing
    Guest
    Main seals? Not common but another possibility.
  2. #2 Re: changing oil pan gasket
    wi
    Well I changed the valve cover gaskets and it appears to still be leaking...Next oil change it'll probably come off...What do you mean lower the sub frame?
  3. #3 Re: changing oil pan gasket
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by ratnick View Post
    I mean you can't just take the bolts off and take the pan off, there's not enough room. You need to support the engine from above and lower the engine cradle/subframe to get clearance to get it off.
    2001 Buick Regal LS - Almost Stock
  1. changing to a l67
    By srziemkowski in forum Off Topic Discussion
    Last Post: 02-10-2009, 09:44 PM
  2. Thinking of changing oil
    By GTP4 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-19-2008, 04:00 PM
  3. changing supercharged oil
    By nemesis in forum General Tech Discussion
    Last Post: 08-06-2008, 12:27 PM
  4. Changing headlights
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 02-26-2008, 08:56 PM
