Thread: No oil pressure!! Need help quick!
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 62
  1. #1 No oil pressure!! Need help quick!
    Jul 2016
    Towanda Kansas
    I replaced the timing chain cover gasket and when I got it all put together I have literally zero oil pressure, I tore it back apart to see if maybe some silicone got somewhere it shouldn't then I put it back together and it's the same thing. It has a 3.8 liter v6 non supercharged engine. Any help would be greatly appreciated.
  2. #2 Re: No oil pressure!! Need help quick!
    did you remove the oil filter housing? if you did did the spring and cap go back in?
  3. #3 Re: No oil pressure!! Need help quick!
    Jul 2016
    Towanda Kansas
    Yes it did go back in.
  4. #4 Re: No oil pressure!! Need help quick!
    you have a o/p gauge your looking at? did it start to knock when it fired up?
  5. #5 Re: No oil pressure!! Need help quick!
    Jul 2016
    Towanda Kansas
    all the lifters aren't pumping up and I am getting no oil from the oil filter when it is off
  6. #6 Re: No oil pressure!! Need help quick!
    fill the oil filter with oil and put it on, take the spark plugs out and crank it for 15 to 20 seconds at a time for 5 to 8 times.
    if you can get a mechanical gauge to put in the op housing, where the low oil sensors is you'll see oil pressure when its cranked. if its getting it.
    why did you change the cover?
  7. #7 Re: No oil pressure!! Need help quick!
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    He replaced the gasket
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  8. #8 Re: No oil pressure!! Need help quick!
    so you didnt take the oil pump or anything apart then. just took it off and put it back on.
    i think it just needs to be cranked more till it builds o/p. dry filter is a no no in my book. always fill them if you can. i know some cars have em sideways. ours we can fill it up.
  9. #9 Re: No oil pressure!! Need help quick!
    Jul 2016
    Towanda Kansas
    I've put a quart over in oil, filled the filter completely and it is still not pumping whatsoever.
  10. #10 Re: No oil pressure!! Need help quick!
    I always install the filters dry, it makes no difference. There is plenty of oil on the bearings for a few seconds it's pumping up.
    Only needed or wanted on diesel trucks, they can blow the filters straight off if no oil is in them.
    His problem seems oil pump related or it's bleeding off straight back into the pan.
  11. #11 Re: No oil pressure!! Need help quick!
    Oct 2014
    Frederick, MD
    I would say check the oil pump first, easiest to get to.
  12. #12 Re: No oil pressure!! Need help quick!
    Jul 2016
    Towanda Kansas
    When I had it apart the second time I checked to see if it was turning smooth but I didn't open it up. I don't understand why it would fail all the sudden like this.
  13. #13 Re: No oil pressure!! Need help quick!
    you got the spring and cap in the housing in right? if thats backwards i dont think you get o/p
  14. #14 Re: No oil pressure!! Need help quick!
    Jul 2016
    Towanda Kansas
    Yes I have it in there correctly.
  15. #15 Re: No oil pressure!! Need help quick!
    Oct 2014
    Frederick, MD
    The oil pump gear might be grooved.
  16. #16 Re: No oil pressure!! Need help quick!
    Jul 2016
    Towanda Kansas
    What would cause that to happen so suddenly
  17. #17 Re: No oil pressure!! Need help quick!
    Feb 2013
    37.295091, -121.930053
    uhhh you touched it
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  18. #18 Re: No oil pressure!! Need help quick!
    Jul 2016
    Towanda Kansas
    I mean technically I didn't touch the oil pump
  19. #19 Re: No oil pressure!! Need help quick!
    have you pulled the oil pressure sensor to see if oil comes out of it? bout a 1/4 qt should leak out if its got oil in it.
  20. #20 Re: No oil pressure!! Need help quick!
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    #following
  1. Hi pressure low pressure fuel connectors , i lost the springs that go inside. help
    By Hardonyomom in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2014, 09:31 PM
  2. Quick AEM Oil Pressure Gauge Question
    By CNorell145 in forum General Grand Prix Discussion
    Last Post: 05-07-2014, 05:05 PM
  3. Quick help please! Just a quick question!
    By nikkigpgt00 in forum Tires & Wheels
    Last Post: 07-31-2012, 12:29 PM
  4. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
