Thread: No oil pressure!! Need help quick!
Results 21 to 40 of 62
  1. #21 Re: No oil pressure!! Need help quick!
    Buffalo
    Yeah I always crank the engine over without fuel/spark to get the oil pumped
    up to the top first (look under valve cover)
  2. #22 Re: No oil pressure!! Need help quick!
    Jan 2014
    AR
    I'm from the filter filler camp. I've never had a 3800 apart. But in the 90s I replaced the timing chain on an older Buick 231 V6 which is of the same configuration and same as the Buick V8s also. The manual I was using indicated that if the oil pump is dry it may not pump. It suggested that the pump be primed with wheel bearing grease around the gears to form an initial fluid seal so theres suction at the pickup. Worked for me, and thats all I got. Good luck!
  3. #23 Re: No oil pressure!! Need help quick!
    Buffalo
    Yup x2
    some even use Vaseline
  4. #24 Re: No oil pressure!! Need help quick!
    Jul 2016
    Towanda Kansas
    Yeah there is no oil in it.
  5. #25 Re: No oil pressure!! Need help quick!
    well that sucks. other then doing the grease or Vaseline deal im out of ideas.
  6. #26 Re: No oil pressure!! Need help quick!
    Buffalo
    I'm suprised that cranking the engine over without fuel/spark has not brought any oil up to the top yet ....
  7. #27 Re: No oil pressure!! Need help quick!
    Jul 2016
    Towanda Kansas
    All I have done is idle it for a few seconds, shouldn't that have brought it too the top as well? Or does turning it over without spark work better to prime the pump?
  8. #28 Re: No oil pressure!! Need help quick!
    Jan 2014
    AR
    Removing the plugs lets it spin faster while cranking. If the pump can't create suction, it won't matter how fast it spins or for how long. But it sounds like most folks don't have this trouble after having the pump out. FWIW, that odd-fire V6 I did the timing chain lived on just fine after having run a few seconds with the lifters dry.
  9. #29 Re: No oil pressure!! Need help quick!
    hangover park IL
    If it is a pump priming issue just fill the crankcase with an additional four quarts of oil in. the oil will get all the way up the sump tube to the pump Inlet passage at the cover make sure you drain it before you actually start it
    ~James~ Psychotic Gearhead
  10. #30 Re: No oil pressure!! Need help quick!
    Nov 2011
    NY
    uhhh you touched it
    Hahaha, beat me to it, and still made me lol... Is the way it is!
  11. #31 Re: No oil pressure!! Need help quick!
    Buffalo
    I would never let the car run / idle whatever to prime the pump.
    It's a hell of a lot easier on the engine to crank it over without fuel/ spark
    yes add oil to the crankcase as well
  12. #32 Re: No oil pressure!! Need help quick!
    Jul 2016
    Towanda Kansas
    what are the chances that all this ****ing around has baked the oil pump?
  13. #33 Re: No oil pressure!! Need help quick!
    the only time ive taken off a timing cover was on the engine i re gasketed, did the same as you took it off cleaned the gasket surface on the cover and block, and put it back on.
    all i did was crank the piss out of it and then fired it up. been fine. that was on a 110,000 mile 1996 l36 engine that i top swapped with ported heads and rockers.
  14. #34 Re: No oil pressure!! Need help quick!
    I pull the fuse for the fuel pump and crank it over a few times.. Never hurts.
    04 Comp G.
  15. #35 Re: No oil pressure!! Need help quick!
    spark plugs out it will crank twice as fast really. and not wear on the battery as much.
  16. #36 Re: No oil pressure!! Need help quick!
    Buffalo
    Soo ... Any luck
  17. #37 Re: No oil pressure!! Need help quick!
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    Make shure the oil filter adapter gasket is sealing correctly. One section of the adapter just seals the passage were oil is sucked into the pump, if it leaks, it will suck air and not prime.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  18. #38 Re: No oil pressure!! Need help quick!
    Jul 2016
    Towanda Kansas
    I am at work currently, when I get home I will try to pull the plugs and fuel pump fuse and turn it over and see if it primes. If all else fails it looks like I will be tearing it all apart for the third time.
  19. #39 Re: No oil pressure!! Need help quick!
    Jul 2016
    Towanda Kansas
    Looking in from the oil fill spout. What should I expect to see when turning the vehicle over?
  20. #40 Re: No oil pressure!! Need help quick!
    not a whole lot, a rocker on each side moving, and a poor view really. if you see oil dripping off the rockers thats a plus.
  1. Hi pressure low pressure fuel connectors , i lost the springs that go inside. help
    By Hardonyomom in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2014, 09:31 PM
  2. Quick AEM Oil Pressure Gauge Question
    By CNorell145 in forum General Grand Prix Discussion
    Last Post: 05-07-2014, 05:05 PM
  3. Quick help please! Just a quick question!
    By nikkigpgt00 in forum Tires & Wheels
    Last Post: 07-31-2012, 12:29 PM
  4. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
