Thread: Alternator Rating?
Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
  1. #21 Re: Alternator Rating?
    Coshocton, Ohio
    I'm running MTX 1501d, the original one, my voltage drops to 10.2-10.5 when the stereo is turned up, and because of that, my amp isn't getting all the juice it wants, Big 3 is done with 4 gauge which did help with massive dimming, but it still dims. At 2000 rpms my alternator is putting out 14.1 80 amps. I'm wanting to switch to a 200 amp alternator but money is tight.
  2. #22 Re: Alternator Rating?
    Willoughby, Ohio
    i have a 2000 watt RMS system (2 amps n 2 12s) i have an optima red top and 2 power acoustik 3 farad capacitors and my lights dont dim at night...all this might be cheaper than a high output alternator
  3. #23 Re: Alternator Rating?
    Coshocton, Ohio
    Quote Originally Posted by CTKGP09 View Post
    Thanks for the input.
    I have found several ho alternator companies that sell 200 amp alts for 2-300 dollars. I'm currently running 1.5 farad cap and the going rate for optima batteries are $160+. when you add batteries all you are doing is extending play time with the car off and you are adding stress to the alternator
  4. #24 Re: Alternator Rating?
    Jul 2008
    iowa
    capacitors do not help just for your info and i would def get a ho alt if its in your budget the only real way to help your electrical and the of course the big three and maybe a new batt up front
  5. #25 Re: Alternator Rating?
    Jul 2008
    iowa
    well i assure you that i am as the amp i am using will definatly put out those number or close to and i have it set with a dmm and it is running fine just dont turn it all the way up and leave it there for very long i usually only play at about half volume so it doesnt pull those amps all the time
  6. #26 Re: Alternator Rating?
    Coshocton, Ohio
    What about the cap buster? it is a battery cap hybrid, it is supposed to be equal to 100 farad cap. just wanting to know opinions
  7. #27 Re: Alternator Rating?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by lucky178 View Post
    Still far too low to be of any real use in overcoming a deficient electrical system. Caps are a good thing, they help transient response, they're just grossly mismarketed in the car audio world.
    2001 Buick Regal LS - Almost Stock
  8. #28 Re: Alternator Rating?
    Jul 2008
    iowa
    like i said best thing is bigger alt and new batt check out one of the audio forums they will tell you the same thing about caps there not worth the money
  9. #29 Re: Alternator Rating?
    QCA, IA
    Quote Originally Posted by 05gpgt View Post
    Yes, that's what they'll tell you, but that doesn't mean they're right. If you've built any audio amplifiers, you know that capacitance on the power rail is a good thing, the lower the ESR the better, but as I said, it's for transient response and ripple reduction, not for proping up a deficient power system. They're not worth it if all you care about is SPL.
  10. #30 Re: Alternator Rating?
    Jul 2008
    iowa
    if yah dont mind me asking what do u run and i guess from the things ive been told and read they just dont do anything in a system
  11. #31 Re: Alternator Rating?
    Jul 2008
    iowa
    do u happen to have anything that i could read online that describes this better and what it exactly does for improving my system?
  12. #32 Re: Alternator Rating?
    QCA, IA
    Believe it or not, I'm not running anything right now, this is from my younger days when I was more into car audio. I have a few things sitting around still, a couple of MTX Black/Gold amps, for example, that I've never gotten around to installing. I really need to, I love those amps and they're impossible to find anymore. I don't have anything online specifically, it's been a while (5-6 years) since I was into amplifier design/building, so my bookmarks are long gone, and a lot of it was in books, anyway.
  13. #33 Re: Alternator Rating?
    Jul 2008
    iowa
    ic just curious ive never been told that before and wanted to see if it really would help at all yah those are definitely some older stuff but good idk what i would do without my system love it need a ho alt really bad though
  14. #34 Re: Alternator Rating?
    Jul 2008
    iowa
    not even sure who makes them for a good price every where i look it well over 300 or so
  15. #35 Re: Alternator Rating?
    QCA, IA
    See, now I got curious, since I'd slowly been selling off my car audio stuff, and I must have sold the Black Gold at some point, as well as my old Rockford amps. All I've got left is an MTX 2300x and a 4300x. Good amps, I should still get them installed at some point.
    Unfortunately, I don't know of anyone that makes HO alts cheap, but I'm thinking I just saw a thread on one of the boards where someone swapped in a CS144 for the stock CS130D. Might be a decent option.
  16. #36 Re: Alternator Rating?
    Springfield VA
    iraggi alts makes a 220/240/280A alt for our models i believe, and i believe mean grean makes a HO alt, but there all fairly pricey
    Quote Originally Posted by UR LOSN View Post
    all depends on how fast/broke you want to go.
  17. #37 Re: Alternator Rating?
    Jul 2008
    iowa
    yah it was well over 300 i tried irragi before and to me thats to much
  18. #38 Re: Alternator Rating?
    Willoughby, Ohio
    1 farad=500watts RMS power...a capacitor RESISTS changes in voltages thereby regulating it...the original alternator is in my car and ive had this setup for 16 months now and never had a problem...guess its a matter of preference
  19. #39 Re: Alternator Rating?
    rhode island
    Have you tried Magic 3 wire setup, I gained around 1v on my setup, I used to run 3 bazooka amps. 2 - 500w, and 1- 140w. I'm also running a 2 farad cap.
    I looked into getting them a while ago, I killed 2 alternator before. Then I regrounded everything, got a cap and then I did Magic 3 and had no problems after that.
  1. Tire size and rating information
    By webracin in forum Tires & Wheels
    Last Post: 03-01-2018, 11:18 PM
  2. alternator
    By Slueth66 in forum General Tech Discussion
    Last Post: 01-29-2009, 10:05 AM
  3. is it my alternator?
    By boosting98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2009, 05:38 PM
  4. Alternator ????????
    By kingbrentdwyer in forum General Tech Discussion
    Last Post: 10-27-2008, 11:01 PM
