Thread: Idle dropping and bouncing??
Results 1 to 20 of 50
  1. #1 Re: Idle dropping and bouncing??
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Ok thanks. So ten minutes in im disconnecting the throttle body and theres two hoses that conjoin into one at the throttle body and where it conjoins there is a huge slice down the middle the two other hoses lead to the evap purfe solenoid and the fuel pressure regulator. Could this be a cause?
    Sent from my LG-D851 using Tapatalk
  2. #2 Re: Idle dropping and bouncing??
    Quote Originally Posted by suitercrew View Post
    that split is your problem. you need to hit a parts store, advance sells the best little t's. you need a Y and some vac line that fits the tb, then some smaller line to push inside the fat line, the Y to the other two small lines and the new line off the tb.
    you'll need to cut or pull off th eold factory rubber end off the hard lines, then put a inch or so of new vac line on the end of the hard lines to the Y.
  1. rough idle and bouncing rpm gauge
    By Flip97GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2014, 01:57 PM
  2. 99 GTP, RPM's bouncing at 11-1600
    By AKGTP19 in forum General Tech Discussion
    Last Post: 03-15-2013, 06:49 AM
  3. Bouncing projectors
    By Ricky21 in forum General Tech Discussion
    Last Post: 05-19-2010, 08:34 PM
  4. high-pitched whistle and bouncing idle
    By CSteen85 in forum General Tech Discussion
    Last Post: 04-28-2010, 07:58 AM
  5. 94 GTP gas smell and bouncing idle
    By rw53104 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 02-17-2010, 02:21 PM
