Thread: 3.69 gears installed! but issues...
Results 1 to 20 of 25
  1. #1 3.69 gears installed! but issues...
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    so gears are installed! but got some issues that i think maybe tune related... idk though would like opinions.
    first issue:it hard shifts,,, like really hard lol, threw all gears,
    second issue: if im in moderate throttle going threw first gear, when it goes into second gear the car keeps accelerating but seems like a loss of power for 2-3 seconds then I get all my power back.. almost seems like its slipping but it isnt... idk. ill send a video
    some reason none of videos will upload and play straight.... so hear is a sideways video lol, i put down the throttle 30% and hold it there, after it goes into second gear 2-3 seconds after youll see the rpms jump a little and it starts accelerating harder, if i take off nice and slow and it goes into second then i get into the throttle it does not do this, if i manual shift it into second and let the rpms go way down then get on it it doesnt do this, only when shifting from 1-2 in moderate throttle this wierd issue occurs.
    turn up the volume you can hear when i get my power back... its weird
    EDIT: 09/15/15 another video https://www.youtube.com/watch?v=A8UfoJIE8ZQ
    I havent gone wot into 2nd gear yet as i dont want to hurt the trans..
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  2. #2 Re: 3.69 gears installed! but issues...
    Aug 2013
    McDonald PA
    Time for more tuning lol
  3. #3 Re: 3.69 gears installed! but issues...
    St Thomas Ontario
    think its just the tune?
    anyone else got any ideas?
    think i should try a wot run and see if anything wierd happends? it seems to shift smoother/softer on harder throttle..
  4. #4 Re: 3.69 gears installed! but issues...
    give it some time, it could just be learning. when i did my trans swap it shifted like a mule kick for while.
  5. #5 Re: 3.69 gears installed! but issues...
    St Thomas Ontario
    Quote Originally Posted by ScottyDoggs View Post
    when i swapped the trans months ago it never shifted this hard.
    I got thinking(hard thing for to do lol) and im gonna unplug the battery and reset the pcm, here is my thoughts.
    I installed the pcm(tuned for 3.69) when my final drive was 2.72.
    i then drove across town to my father inlaws garage to get my gears installed, got the gears installed... but never unplugged the battery to reset the pcm.
    so the pcm wants 3.69 gears, i drove for 10 min with 2.72 gears, didnt reset the pcm, then drove with 3.69 gears....pcm is thinking wtf maybe?? lol
  6. #6 Re: 3.69 gears installed! but issues...
    Nov 2013
    United States
    Did you adjust the shift points? Sure you can change the gear ratio, but the shift points could still be off.
  7. #7 Re: 3.69 gears installed! but issues...
    St Thomas Ontario
    overkill did the tune. I have emailed him also to see what he thinks.
  8. #8 Re: 3.69 gears installed! but issues...
    Once you've driven and it shifts hard, scan it w/o turning off the ignition. Bet you see a max adapt code. Which would mean it's pissed off.
    I'd think this is likely in the tune. 2.72 vs 3.69 should have been very close and likely should have run fine on the tune.
  9. #9 Re: 3.69 gears installed! but issues...
    St Thomas Ontario
    overkill thought maybe we messed something up in the valve body,but we took that off all in one piece following your 4th gear replacement guide (http://www.grandprixforums.net/threa...e-cover-access) so cant be that, so gonna try to rest the pcm see if that helps, if not scan it see what code pops up and go from their.
  10. #10 Re: 3.69 gears installed! but issues...
    I wonder about the programming.
  11. #11 Re: 3.69 gears installed! but issues...
    St Thomas Ontario
    ya im thinking it maybe tune related also, overkill has been very helpfull and replies quickly with any questions I have so ill get this fixed sooner or later I have no doubt. Once the wife gets up im gonna unplug the battery and see if that helps, kinda doubting it but never know...fingers crossed lol. if it doesnt work I might ask blue to send his trans settings to overkill cause he has his 3.69 gears in and working properly.
  12. #12 Re: 3.69 gears installed! but issues...
    I doubt it as well. Trans stuff typically resets at ignition cycle.
  13. #13 Re: 3.69 gears installed! but issues...
    GT Level Member Overkill's Avatar
    Nanaimo British Columbia
    Programming is 100% correct, I program my gear ratio changes with the correct method and not the skew method which is the difference with one program versus the other. I had 3.69s on my GTP, I've programmed for 3.69 gears a few times before!!!!!!!
    Same trans was shifting nice on the previous gears when I in-car tuned it a few months ago. Same pressure settings on the new 3.69 gears. See how it is after you reset the computer.
    Email all inquiries to willoverkill@gmail.com!
  14. #14 Re: 3.69 gears installed! but issues...
    Will.. if you could, please get Erich the file. I'm waiting on this thing too long. Thanks
  15. #15 Re: 3.69 gears installed! but issues...
    St Thomas Ontario
    Unplugged the battery for a few hours and went for a drive. Shift fine from 1-2 and 2-3 once. Then i came to a stop sign and took off again and it started shifting hard again And that other wierd issue i described in the original post.
  16. #16 Re: 3.69 gears installed! but issues...
    File for what? He was going to get one of my MAF sensors but from my records I never received payment and never shipped a MAF. Let me know what's needed
  17. #17 Re: 3.69 gears installed! but issues...
    Peter, missed you on Facebook but left you a message there with a question
  18. #18 Re: 3.69 gears installed! but issues...
    St Thomas Ontario
    I replied WIll.
    Drove the car to work. The car also bogs with the 2-3 shift and i think 4th gear also but 4th is harder to tell. doesnt really matter if im heavy on the throttle or light it does it.
    So does that weird bog thing every gear.
  19. #19 Re: 3.69 gears installed! but issues...
    Quote Originally Posted by Overkill View Post
    I'd rather not be involved. Please reach out to your customer
  20. #20 Re: 3.69 gears installed! but issues...
    St Thomas Ontario
    ok got youtube to fix my videos, here is the best one i got of the weird bog out issue, when it shifts into second you can see after 2-3 second the rpms jump and the engine sounds like I applied 10-20% more throttle...but my foot stays in the exact same position.
    you can see it more when i come to a complete stop and try again
  1. intercooler, 42 lb injectors, and north star tb installed and having issues.
    By SgtMarshal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-19-2014, 10:08 PM
  2. Stainless Steel Brake Lines (Installed, Issues)
    By FriboRage in forum Brakes/Suspension/Chassis
    Last Post: 05-30-2014, 12:15 AM
  3. Retrofits installed, having issues, please help!
    By ffball33323 in forum Visual/Body Modifications
    Last Post: 04-02-2014, 12:10 PM
  4. Headers installed, stuttering issues now
    By tu8i1o7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2011, 10:17 PM
  5. Installed plog (and DP) and now issues! (w/vid)
    By SliceTheRice in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2010, 07:03 PM
