Thread: Stock rebuild recommendations needed
Results 1 to 7 of 7
  1. #1 Stock rebuild recommendations needed
    Mar 2014
    Tucson
    Background; (blue text=hyperlinks)
    I’m bench building a 4t65e-hd for a STOCK 2001 GTP. The core I’m using was previously pulled from a 2002 Regal GS. It was pulled because of the codes that it was setting;
    a. P0742 (Torque converter clutch stuck on)
    b. P0757 (Shift solenoid "B" stuck on)
    When pulled, it was still functioning, just bucking or surging when warm at speeds above about 40mph. From the research I've done, and what I saw during the tear down, it looks like the torque converter failed and sent debris throughout. No catastrophic failures though. Trans had only had 43k on it. I’m assuming it was a GM reman unit based on the “GM Parts” sticker on the side cover, and the lack of a metal spec tag. Just a sticker on the housing. That being the case, it already has a lot of the later model year upgrades. (like the hardened 4th)
    So, here’s my questions;
    1.) Do I really need a “master” kit for a core with 43k on it? Or is an overhaul kit good enough? Is it possible that TC grit damaged the frictions, bearings or bushings? What do you recommend, based on condition of the components shown? (Link to pictures)
    2.) Should I replace all or some of the solenoids and MPS? (based on the PCM codes) Or can I just clean and test? (Ohm the resistance?) - Leaning toward replacing...
    3.) What other parts would you recommend?
    a. Sonnax TCC relief valve
    b. Gemini chain (stock chain is barely within spec)
    c. Precision of New Hampton torque converter
    After a complete tear down, I am very impressed with the condition of everything.
    a. All measurable components within spec per the ATSG
    b. No chips or burrs on any of the gears
    c. No ratcheting on the input/3rd sprag or 1/2 roller clutch
    d. No heat checks on any of the steels
    →e. After pulling some of the valves, it looks like I will need to pull every valve and thoroughly clean valve and bore. They were all sticking at least a little due to the grit in the system.
    If I were building this unit for my MY car, I would just buy a master kit and be done with it. However, this trans is going in my father in laws stock car. Money is a big factor on this project. That is the main reason I’m building it myself instead of the local transmission shop. I’m trying to strike a balance between cost and reliability. He is planning on driving this car back to Michigan withing a year. I want to make sure this trans is super reliable, but I don’t want to replace any parts unnecessarily.
    I’m using DVD video manual and the ATSG service manual for reference.
  2. #2 Re: Stock rebuild recommendations needed
    I'd automatically send the VB/CP to Dave. Tell him your mods that you plan to end up at the codes it was showing. He'll do all the updates/upgrades to those parts and the spacer place. Literally it comes back to you ready to bolt on.
    As for clutches, I'd go through and ensure the packs are properly clearanced to whatever Greg says they are supposed to be vs the stock GM "toss X frictions and steels in and hope for the best". That's not clearancing. That's an issue waiting to set a P1811.
    Then toss in a transgo shift kit, new chains (all are v8 spec now), and a lube tube retainer presto.. you'll have a nice trans.
  3. #3 Re: Stock rebuild recommendations needed
    Mar 2014
    Tucson
    Thanks Bill. Who's Greg?
  4. #4 Re: Stock rebuild recommendations needed
    ^GMR Badass
    04 Comp G.
  5. #5 Re: Stock rebuild recommendations needed
    Mar 2014
    Tucson
    Ahh, I see. For a minute there I thought Bill personally knew the guy from the DVD. (He goes over checking the friction clearance in the video)
  6. #6 Re: Stock rebuild recommendations needed
    Never know.. did GMR Pansyhands ever do a vid?
  7. #7 Re: Stock rebuild recommendations needed
    Mar 2014
    Tucson
    I'm not sure. The DVD I bought shipped out of Columbus, New Jersey. Where's GMR Badass from?
  1. [exhaust] stock replacement recommendations
    By localhost127 in forum General Tech Discussion
    Last Post: 01-08-2014, 05:52 PM
  2. About to begin my rebuild. Input needed
    By OrangeL67 in forum General Tech Discussion
    Last Post: 08-27-2011, 01:07 PM
  3. Total engine rebuild, advise needed.
    By machinegunsquid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2011, 09:07 PM
  4. Tools needed for rebuild?
    By TMC in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-16-2010, 11:16 PM
  5. Tranny Tools Needed for Rebuild
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-05-2008, 07:20 PM
