Thread: Transmission Swap
Results 1 to 7 of 7
  1. #1 Transmission Swap
    SE Level Member philly387's Avatar
    May 2015
    Michigan
    I had a used transmission put into my 1998 Grand Prix GTP Supercharged. The problem I have is it doesn't seem to shift at the right times.
    When I have the performance shift on, it seems to shift a lot better like the original transmission did before it took a crap.
    Any ideas?
  2. #2 Re: Transmission Swap
    We are going to need a lot more info to be able to offer good suggestions.
    Start off by checking the fluid level.
    Then.. what did the transmission come out of? How many miles on it etc etc etc
  3. #3 Re: Transmission Swap
    May 2015
    Michigan
    Looks good.
    Came out of the same car but with 120k miles on it. Mine has 187k miles on it.
  4. #4 Re: Transmission Swap
    Don't have much to give you for info then. If it's the same year/same car it should be the same trans.
  5. #5 Re: Transmission Swap
    May 2015
    Michigan
    Never mind he just told me a Buick regal
  6. #6 Re: Transmission Swap
    If it was from a SC buick regal, then it's also the same trans.
  7. #7 Re: Transmission Swap
    May 2015
    Michigan
    Yeah it was. Would anything like the gear ratios be different?
  1. Transmission swap...
    By Booba5185 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-10-2014, 06:24 AM
  2. Transmission Swap
    By waynecheek in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-08-2013, 07:42 AM
  3. Transmission swap.
    By Tuner-Extraordinaire in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-13-2011, 01:54 PM
  4. Transmission Swap
    By cmal37 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-30-2011, 08:42 PM
  5. transmission swap
    By jrock in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-13-2011, 01:04 AM
