Thread: New (er) Transmission Problems...Irritated.
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
  1. #21 Re: New (er) Transmission Problems...Irritated.
    you try spraying the injectors and the blower base with carb cleaner to look for a vac leak?
    hows that trans tune?
  2. #22 Re: New (er) Transmission Problems...Irritated.
    Feb 2013
    Missouri
    So far it's great with the trans tune, I couldn't be happier! I've done the red neck smoke test for vacuum leaks and found none. I try to avoid the carb cleaner stuff cuz of the paint. I am throwing around the idea of getting a set of rebuilt injectors. I've also changed the stock fuel pump power wire to a 10 AWG so it's got solid voltage. It looked like the PO had swapped in a new pump with the different connector. New fuel filter about 8k ago, so injectors are about all that's left.
  1. Transmission problems again on my '05 GP
    By kyliek23 in forum General Grand Prix Discussion
    Last Post: 06-13-2013, 02:32 PM
  2. 01 gtp transmission problems
    By built01gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-20-2013, 11:34 PM
  3. Transmission problems!!!!!
    By tonio301 in forum Forum Bugs/Suggestions
    Last Post: 10-11-2012, 10:04 AM
  4. 97 GTP Transmission problems
    By greenfiero1986 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-17-2011, 06:18 AM
  5. I got irritated today and.....
    By JESSEGOTTA GP GT in forum Tires & Wheels
    Last Post: 02-18-2010, 07:25 PM
