Thread: hp vs mods
Results 1 to 20 of 36
  1. #1 hp vs mods
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Hi, so i have heard a lot of different things about the 4t65e hd transmission.
    What i really want to know is how much HP can the stock tranny support, after that what mods need to be done to reach the next level, and what will that support etc...
  2. #2 Re: hp vs mods
    GTP Level Member TwinV6GTP's Avatar
    May 2013
    Gatineau
    Quote Originally Posted by 04lss View Post
    FWD with little traction, I've had great luck with the stock trans myself. 11.0 @ 129 mph with weight reduction many runs no problems.
    But I do 2nd gear start with the trans in manual mode. That really helps. The 1-2 shift is deadly. A 2nd gear start makes for a more progressive loading with more converter slip... in a good way.
    still got decent 60 foot with high 1.6s - 1.7s
    If you hook really hard with big slicks on a sticky track, I think you could hurt a stock trans easily, especially with a 1st gear start.
    2015 Custom Twin Engine Nascar style car with dual GTP 3.8 drivetrain, Front trans 4T65e-HD, Rear 4t80e trans 1/4 mile 8.38 @ 165mph
    2000 GP Twin Engine Twin TD Turbo kits. Stock engines stock trans(s) stock injectors stock MAFs 0-60mph 1.8 seconds 1/4 mile 9.72 @ 139 mph
  3. #3 Re: hp vs mods
    Depends on how it was taken care of prior to you owning it.
    You'll never know until you start tossing mods at it.
    Most (and I say this loosely)...have issues after IC and a really small pulley...or camming...hitting that 300+WTQ normally starts breaking things.
    Some have better luck...some break things on stock N/A cars with 160WHP.
    it's a shot in the dark, really.
  4. #4 Re: hp vs mods
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    I agree with blueguy, my trans has held up to my very mild 3.6-3.4 pulley setup (switched a few times) for over 50K miles now... transmission is still factory untouched at almost 278K. Guessing that was around 230-250 FWHP based on dyno runs of similarly modded cars.
    I keep the fluid and filter fresh and clean, as the previous owner has. Aside from that, it's probably luck.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  5. #5 Re: hp vs mods
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    I swapped transmission 3 years ago for hardshifting.. now 3 years later I got slip and bang from a stop and hard shifting from slipping...
    like blue said some have good luck some dont
    I dont... and im only N/A
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  6. #6 Re: hp vs mods
    Jul 2012
    Chicago
    All about that maintenance. But the neighborhood of 300whp will start breaking hard parts.
    -Carl
  7. #7 Re: hp vs mods
    St Thomas Ontario
    I did maintenance, no help, 4t65e sucks.
    yes im really mad at my car lol
  8. #8 Re: hp vs mods
    Mine just broke 1-2 shift kills it
  9. #9 Re: hp vs mods
    May 2013
    Gatineau
    2nd gear starts for the strip or for the street a very early shift to 2nd gear with smaller turbo work really well. Thats what kept my stock trand alive in two different turbo gtp
  10. #10 Re: hp vs mods
    Sep 2014
    Richmond Virginia
    Down the road i might turbo it... but i know with trans mods thats going to run me about 4-5k. So for now im thinking headers, gutted factory CAI, and an IC, maybe e85. with what ever pulley i can get away with, maybe rockers.
    im guessing thats about 250-260 whp But Im not sure. I drove a g37 a couple times this year as a loaner, and id really like the car to be in the same realm as that performance wise and i think id be happy for a while.
    the trans on this car was just rebuilt, before my brother decided to stop putting money in the car when he got his a4.
  11. #11 Re: hp vs mods
    Nov 2012
    Erlanger, KY
    YEEEEARS ago.. my 98 GTP went through 4 stock trannys covered under warranty in a 2-3 year period.
    Only mods back then was 3.4", intake, ubend removed.. maybe rockers. Car was only the mid to high 13's.
    Some of them would last a few months and only a few dozen runs at the track.
    They would go bad while driving down the road or leaving from a stop and something would snap inside.
    None of them blew a diff. Always bands and clutches just going to hell.
    My PRJ trans got me about 6-7 years of use before started to show some slipping.
    2001 Turdbo Grand Prix GTP - 10.41@132
    Videos @ https://www.youtube.com/user/jdredd34
  12. #12 Re: hp vs mods
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by jdredd View Post
    Im mainly looking for mid to low 13s, and better handling
  13. #13 Re: hp vs mods
    May 2008
    Schuyler, NE
    I wish I would have tried launching in 2nd gear back when I sprayed nitrous. The input shaft probably wouldn't have snapped on that 175 shot pass.
  14. #14 Re: hp vs mods
    May 2012
    Where winter never ends
    If you plan on going turbo. Build the trans for it. This isn't a hard question. The trans WILL break at ~wTQ.. Its just a matter of when and how you drive.. DSmuts snapped his IS very very quickly, I on the other hand have not broke anything but I know its dying... I can feel it.
    2000 Regal - Winter Beater
  15. #15 Re: hp vs mods
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by adecker View Post
    Im trying to figure out the balance of keeping the trans moderately safe, and building more power.
    I like to think i could do the turbo and wait for the trans build before i up the boost.... I wouldnt last a week lol.
    on a side note, i could always get a junkyard tranny for $200 and build that as i get the money, and swap it in when stock on shatters. hmm
  16. #16 Re: hp vs mods
    You can keep your trans safe by keeping the shifts soft. Rock hard shifts is what breaks stuff if you have to much power
  17. #17 Re: hp vs mods
    Quicker shifts.
    Less contact times.
    Longer trans life.
    You crazy, Dannnnn.
  18. #18 Re: hp vs mods
    The Boss Iceman6669's Avatar
    Jun 2011
    Quote Originally Posted by blueguy View Post
    Quicker shifts.
    Less contact times.
    Longer trans life.
    You crazy, Dannnnn.
    This. Firm up the shifts and it will last longer.
    2011 F-150 Yote powered
  19. #19 Re: hp vs mods
    My trans was fine until I firmed up the shifts just a little more then boom.
  20. #20 Re: hp vs mods
    Probably because of the power level.
    And the prior condition.
    And the mileage.
    Not because of the shift times, lol.
  1. Trade 98 GTP lite mods for GTP with mods
    By Shifty in forum Wanted To Trade
    Last Post: 10-20-2012, 07:52 PM
  2. gtp mods
    By 03limitedgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-14-2011, 10:59 AM
  3. mods
    By Moriarity81 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2011, 03:14 PM
  4. 05 GTP Mods
    By shanester in forum General Tech Discussion
    Last Post: 06-12-2009, 10:25 AM
