you try spraying the injectors and the blower base with carb cleaner to look for a vac leak?
hows that trans tune?
So far it's great with the trans tune, I couldn't be happier! I've done the red neck smoke test for vacuum leaks and found none. I try to avoid the carb cleaner stuff cuz of the paint. I am throwing around the idea of getting a set of rebuilt injectors. I've also changed the stock fuel pump power wire to a 10 AWG so it's got solid voltage. It looked like the PO had swapped in a new pump with the different connector. New fuel filter about 8k ago, so injectors are about all that's left.
