Thread: Transmission problems again on my '05 GP
Results 1 to 10 of 10
  1. #1 Transmission problems again on my '05 GP
    GT Level Member kyliek23's Avatar
    Feb 2013
    Ok, so i posted about my transmission before and fixed the problem. Now i have another issue with it. i feel its slipping a little bit when im stopped on a hill because of traffic lights. when im stopped and waiting to go it seems like it runs fine but then when the light turns green i take my foot off the brake and apply the gas it doesnt go and then jumps into gear. kind of scares me. can anyone help me??
    2005 Pontiac Grand Prix Base
  2. #2 Re: Transmission problems again on my '05 GP
    Ever do a pan drop and filter change? If not do that and put a bottle of lucas stop slip in it.
  3. #3 Re: Transmission problems again on my '05 GP
    Feb 2013
    i changed the filter, gasket and fluid in it about id say 5,000 miles ago. i was thinking about doing the lucas stop slip in it. what do i have to do to put that in?
  4. #4 Re: Transmission problems again on my '05 GP
    drain a little out of your trans and then just add to it
  5. #5 Re: Transmission problems again on my '05 GP
    Feb 2013
    ok. that applies to the oil as well. i wanted to put some of that lucas stuff in my oil as well. they come in 1 liter bottles right?
  6. #6 Re: Transmission problems again on my '05 GP
    i over filled my friends tranny a bit when doing his pan drop. i took a clear rubber tube that fits inside the dip stick tube for the trans, and sucked the fluid up the tube. it was a long tube, so it could reach the ground, and bottom out in the pan, sucked the fluid out via siphon action.
    clear tube is key here, so you dont suck it into your mouth, yuck lol once the fluid level is coming down the side of the car in the tube it should flow on its own, keep the end of the hose lower then the pan bottom, fill a quart container, then pinch the hose, lift it up higher then the engine and let whats in the hose drain back into the trans.
    now that one quart is removed, dump the lucas in.
  7. #7 Re: Transmission problems again on my '05 GP
    Feb 2013
    ok. Thank you! ^
  8. #8 Re: Transmission problems again on my '05 GP
    oh, fill that quart inside a catch pan, you'll leak some. its how it goes most of the time. or do this in a dirt lot, ramps help to raise the front end, or jack it up. but jack it level.
  9. #9 Re: Transmission problems again on my '05 GP
    I have one of those cheap orange/black pumps.. works like a champ in cases like this.
    What was your previous issue?
  10. #10 Re: Transmission problems again on my '05 GP
    SE Level Member Crispykit's Avatar
    Apr 2013
    Canada
    I used Lubegard 60902 when I had a Transgo Shift Kit and Aluminum Transmission pan installed. The Aluminum Transmission pan has a drain plug so future additions can be done easily. The transmission was shift banging a little sometimes and the car has 217,000 kms on it so might have been overkill. It works perfectly now.
    Crispykit 2001 GP GT
  1. 01 gtp transmission problems
    By built01gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-20-2013, 11:34 PM
  2. Transmission problems!!!!!
    By tonio301 in forum Forum Bugs/Suggestions
    Last Post: 10-11-2012, 10:04 AM
  3. Transmission problems. Can anybody help?
    By mrbee in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-21-2012, 10:41 AM
  4. Transmission Problems
    By gunters96lt1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-23-2012, 08:49 PM
  5. 97 GTP Transmission problems
    By greenfiero1986 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-17-2011, 06:18 AM
