Thread: Shift kit question??
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21 Re: Shift kit question??
    SE Level Member A98GTP's Avatar
    Apr 2014
    Texas
    ^^^^^ The transgo kit will be perfectly fine. The only way you really will see more performance is upgraded boost valves and valve body changes that arent a quick easy swap and usually require reaming of the valve bores and such.
  2. #22 Re: Shift kit question??
    Sep 2013
    California
    Well after I do the shift kit I'm going to start work on my heads... I don't want to keep having to change the shift kits I just want one that would be like a street/strip and after the head work it should be real fun...
  3. #23 Re: Shift kit question??
    Aug 2011
    'Merica
    Then go thrasher if you age going to mod the car....then when the trans breaks give a call to Dave at TEP
  4. #24 Re: Shift kit question??
    Quote Originally Posted by Below Average Joe View Post
    I've been in this car. Shifts great if you are modded, but a little too much if you are stock. Transgo is just fine for a stock car.
    Shifts like racecar
  5. #25 Re: Shift kit question??
    Aug 2011
    'Merica
    When its running proper.......wait it's a GP
  6. #26 Re: Shift kit question??
    Apr 2011
    Vassar, Mi
    If you really want to correct the shifts pull the VB, put in the sonnax boost valve, TC apply valve, updated afl and drill out the bypass holes in the separator plate. If the only parts your going to install out of the shift kit are the accum. springs it doesn't matter which kit you buy. They all do the same thing. **** if you just want to make it bang into gear just buy some tubing in the same dia. as the accum. pins and cut them to length. Take the springs out, put the solid spacers in. Defeat the accum. function completely for $10
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  7. #27 Re: Shift kit question??
    Ding ding ding
    and that's what I've been saying
  8. #28 Re: Shift kit question??
    Sep 2013
    California
    Quote Originally Posted by Anthony Smith View Post
    Do those valves come with the kit?
  9. #29 Re: Shift kit question??
    Apr 2014
    Texas
    No those valves are purchased from a company called sonnax and like I stated before you usually have to ream the valve bores with a reamer and thats not something you should really attempt if you dont know what your doing. Transtar will sell you a valve body that has all the sonnax upgrades done to it already. Couldnt tell ya a thing on the price but you could give them a call.
  10. #30 Re: Shift kit question??
    Apr 2014
    Texas
    P84740-2 4T65e 97-02 w/2-piece pump design (1)
    w/updated Tcc/Boost valves
    w/holley ePc solenoid (2)
    w/new ePc solenoid/PSM
    w/large PSM (3)
    I have the catalog and there is the part number but you have to call for pricing.
  11. #31 Re: Shift kit question??
    May 2013
    Upstate NY
    I had the zzp kit in my 99. It blew the 2nd gear apply piston into about 6 pieces. The zzp kit says right in the directions it will cause hard part failure. I'd avoid that kit like the plague.
    04 CompG, black HAI, 180*, TR55s, custom tune by me, SD headers soon
    04 CompG, fusion orange, all stock
    99 GTP, red, coupe, 3.4, SLP exhaust, basic mods, PB 13.56, SOLD in 09.
  1. diy shift kit question..
    By IntenseFace in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-29-2012, 12:18 PM
  2. 99 GTP shift question
    By GTP78 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-08-2012, 06:12 AM
  3. Another shift kit question
    By Compg4me in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-22-2012, 09:32 PM
  4. shift kit question?
    By hardrocrick in forum General Tech Discussion
    Last Post: 08-26-2011, 06:24 AM
  5. Perf shift question.
    By WhiteGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-30-2008, 08:44 PM
