Hi
I was reading the how to on hooking up the perf shift. I assume I need the shift handle and wiring. Can the wiring just be added to the pcm harness and it should work or do I need to get the pcm from the car I get the other parts from? Also, where is the pcm located under the hood? Any other info on this would be appreciated. Thanks!
