Thread: diy shift kit question..
Results 1 to 10 of 10
  1. #1 diy shift kit question..
    grand forks,nd
    Today I bought 8 qts. Of fluid, a bottle of Lucas, and a new filter. I also went to ace hardware and bought 2- 1/2" spacers and 2- 3/4" spacers. My question is, which correct spacers go in the 1-2 shift accumulator and the 3-4, and also, can I reuse the accumulator gasket?
    2000 silvermist GT... HPtuned, RallyArmor flaps, 6K headlights, 12K fogs, D.I.Y. shiftkit, flipped dogbones, Plastidipped roof, debadged, led interior, custom 3.5" CAI and is far from racekar... for now
  2. #2 Re: diy shift kit question..
    Yes the gasket can be re-used.
    You still want the upgraded springs, those spacers arent going to do much without those springs.
  3. #3 Re: diy shift kit question..
    SE Level Member nukkinfuttz's Avatar
    Sep 2012
    Richmond Va
    The ZZP kit only comes with the spacers, no springs and people seem to give it good reviews. I wouldnt say the springs are a deal breaker. I put the ZZP kit in my car and it made a change for the better. Sorry, I threw the instructions away, so i cant help you with spacer placement.
    91BerettaGTZTurbo=Holset HX-35,26PSI,Bored,EagleRods,WisecoPistons,O-rigned,TitanCopperHG, adj Cam Gears,Custom turbo mani,TurboSmart36mmWG,Screamer Pipe,Custom 3"turboback,MSII-E, LC1Wideband, PyroMeter,KnockSense,Walbro 255LPH,75lbs/hr inj's,3"Core42"Wx15"T IC,HKS BOV Waterinjection,antilag,6puckClutch,Slicks, just needed a Part Number
  4. #4 Re: diy shift kit question..
    exactly why the ZZP is junk, doesnt come with the correct parts to make it the "shift kit" fix it kit.
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    But ZZP does it, so it must be true!
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
    Ohio
    Zzps spacers also mushroom out within a couple thousand miles.
    Intense, Thrasher or trans go...
  7. #7 Re: diy shift kit question..
    grand forks,nd
    ..so I should go to O'Reillys tomorrow and pick up the spring? I heard its only like 6 bucks or so
  8. #8 Re: diy shift kit question..
    The 1-2 has 2 springs and the 2-3 has 3 springs, all different sizes.
    Just buy a shift kit and do it right.
  9. #9 Re: diy shift kit question..
    Ontario
    Its like 100 bucks for a proper shift kit. As FFDP already stated, go with a well known shift kit manufacturer. A transmission is not something you put "DIY" parts into.
    Quote Originally Posted by Oxfire View Post
    Amen
    04 Comp G.
  1. 99 GTP shift question
    By GTP78 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-08-2012, 06:12 AM
  2. Another shift kit question
    By Compg4me in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-22-2012, 09:32 PM
  3. Performance shift question
    By LeadFoot in forum General Grand Prix Discussion
    Last Post: 02-16-2012, 08:00 AM
  4. shift kit question?
    By hardrocrick in forum General Tech Discussion
    Last Post: 08-26-2011, 06:24 AM
  5. Shift solenoid question
    By bretz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-26-2010, 10:52 PM
