Thread: What should I replace on a used 2004 4t56e
Results 1 to 20 of 25
  1. #1 What should I replace on a used 2004 4t56e
    Jan 2014
    Rice Lake
    Chris from Wisconsin again. Thank you all for your input on my last question. I have found a used 4t65e with 84,XXX miles from an Impala with the 3.8l that was a rear hit. With the tranny out, should I replace Anything prior to putting it in? I greatly appreciate your input.
  2. #2 Re: What should I replace on a used 2004 4t56e
    put it in the car, then drop the pan and filter, add 8 qts of new tranny fluid and a new filter. call it done.
    blow your tranny lines out as well as the tranny cooler in your cars rad. you dont want any of your old fluid getting into the new/used tranny.
  3. #3 Re: What should I replace on a used 2004 4t56e
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    I would consider pricing some of the known things that can go wrong in the valve body and replace those before installing it. Triple Edge Performance can help you with those.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  4. #4 Re: What should I replace on a used 2004 4t56e
    What year is your car??
    Because that transmission if you are saying its from a 2004 might not even work with your car.
  5. #5 Re: What should I replace on a used 2004 4t56e
    ^^^^This
  6. #6 Re: What should I replace on a used 2004 4t56e
    Dec 2012
    troll land
    Front pump seal is a good idea. On the year thing you can change the electronics and use it in a 2002 and older car
  7. #7 Re: What should I replace on a used 2004 4t56e
    Jan 2014
    Rice Lake
    Sorry about that, I have a 2004 Grand Prix (also, it is a 4t65e, not 56). Huge thank you on the tips, I completely forgot about blowing the lines out and the front pump seal.
  8. #8 Re: What should I replace on a used 2004 4t56e
    They may have different gear ratios. I'd check that out first
  9. #9 Re: What should I replace on a used 2004 4t56e
    Dec 2012
    troll land
    VERY good idea. I didnt check when i 4t65 swapped my car and with the cel it does all kinds of retarded things. Good tip.
  10. #10 Re: What should I replace on a used 2004 4t56e
    Jan 2014
    Rice Lake
    [QUOTE=They may have different gear ratios. I'd check that out first
    From what I have found, there is an FR-2 and an FR-9 gear code. Do these numbers sound correct? Where do I find the ID tag on the transmission to verify?
  11. #11 Re: What should I replace on a used 2004 4t56e
    There are I think 4 different gear ratios 2.86 2.93 3.05 & 3.29
  12. #12 Re: What should I replace on a used 2004 4t56e
    Dec 2012
    troll land
    I know the impala will have either 3.05 or 3.29 gears. I thimk fr9 is the 3.29 ratio. Keep in mind youll need to use your original neutral safety switch
  13. #13 Re: What should I replace on a used 2004 4t56e
    Mar 2013
    Colorado - USA
    Don't forget to install a Sonnax P/N 84532-01K. An aluminum pan is also nice for the drain plug and the added cooling.
    http://www.grandprixforums.net/showt...74#post1110374
    E85 L32 S1X Heads 105#Crow Springs LQ4 2k+NStarTB Deka 60# Gen1 SLP Headers Stock Plugs
    19 deg GFS and ZERO KR@14 PSI <10% LTFT
    GMPP Struts/Springs SLP Sway Bars Z06 Brakes
  14. #14 Re: What should I replace on a used 2004 4t56e
    Jan 2014
    Rice Lake
    Quote Originally Posted by Shmoke View Post
    Man, All you guys are awesome (in a guy way), I hope someday I have a bit of knowledge to return the favor, THANK YOU SO MUCH!!!!
  15. #15 Re: What should I replace on a used 2004 4t56e
    Jan 2014
    Rice Lake
  16. #16 Re: What should I replace on a used 2004 4t56e
    Jan 2014
    Rice Lake
    Quote Originally Posted by l67ss View Post
    The salvage yard confirmed it is a 3.05 tranny. Do you know where to look on my GP tranny for an ID tag?
  17. #17 Re: What should I replace on a used 2004 4t56e
    Dec 2012
    troll land
    You can check your trunklid for rpo codes. Theres a tag on the tranny bit it needs to b oit to read it
  18. #18 Re: What should I replace on a used 2004 4t56e
    Dec 2012
    troll land
    Im guessing it has 3.29s tho
  19. #19 Re: What should I replace on a used 2004 4t56e
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    L67SS....what front pump seal are you talking about?
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  20. #20 Re: What should I replace on a used 2004 4t56e
    Dec 2012
    troll land
    Lol i think the parts store calls it a torque converter seal
  1. Replies: 8
    Last Post: 05-15-2017, 09:03 PM
  2. how do you replace stock exhaust tips? 2004 gtp
    By DrSnazzy in forum General Tech Discussion
    Last Post: 02-21-2013, 04:07 PM
  3. 3,1 to replace 3.8 in 98' GT?????
    By Dan Hammes in forum General Tech Discussion
    Last Post: 09-14-2012, 04:58 PM
  4. 2004 lincoln Lsv8 or 2004 GP GTP?
    By Enjoijoe in forum General Tech Discussion
    Last Post: 03-10-2009, 03:58 PM
  5. what do i need to replace
    By guy87 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-27-2009, 07:30 PM
