Thread: help break transmission
Results 1 to 20 of 45
  1. #1 Re: help break transmission
    Mar 2012
    NC
    If all else fails, unplug the transmission range sensor causing the trans to go into "limp mode" which will give you reverse and second gears only. Then all you need is a heavy right foot and let the thing die! Just remember to plug it back in and clear the codes before taking it to get fixed.
  2. #2 Re: help break transmission
    detroit
    thanks sounds easy enough
  1. What did i break?
    By NR92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2011, 08:30 PM
  2. First Break down
    By Panther427 in forum 5.3L V8 (LS4)
    Last Post: 02-05-2010, 01:24 AM
  3. not new but took a break
    By WhiteDevil in forum Introductions/Noob Questions
    Last Post: 10-06-2009, 07:59 AM
  4. What did I break?
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-01-2009, 02:22 AM
  5. break job help
    By reinke in forum Brakes/Suspension/Chassis
    Last Post: 11-17-2008, 08:42 PM
