Thread: Popping
Results 1 to 7 of 7
  1. #1 Popping
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    kay i know i am probably due for some maintenance, but here's my problem, there is an audible Popping/clunking sound coming from the car when i turn it on, shift it out of park, then shifting back into park, and shutting the car off.
    i am assuming this is the transmission, but could it be anything else too?
    and if it is the transmission, do i just need it serviced?
    i will try to get a video with it once i find my camera
  2. #2 Re: Popping
    It could be motor or trans mounts.
  3. #3 Re: Popping
    Mar 2012
    Minneapolis MN
    i flipped my upper motor mounts recently, could that do it?
  4. #4 Re: Popping
    St. Louis
    Possible, but worn out motor and trans mounts could too. If yours are stock and you've never changed them then its time. Did it make this noise BEFORE you flipped the dogbone mounts?
    Mar 2012
    Minneapolis MN
    No it did not make the noise beforehand. And with 212k on the body I figured it might be due for some maintenance
  6. #6 Re: Popping
    St. Louis
    Sounds like you've found your culprit. I'd change out the motor and trans mount and see what that gets you. If the pop is still there then dogbones too. I wouldn't throw money at the dogbones just yet until you see what the new mounts do for you. I'd be willing to bet they are shot. Any vibrations while you're driving?
    Mar 2012
    Minneapolis MN
    Only when shifting, otherwise the engine is pretty smooth
  1. popping noises
    By Jakegday in forum General Tech Discussion
    Last Post: 08-16-2011, 06:40 AM
  2. popping noise.
    By wlmrt6 in forum Brakes/Suspension/Chassis
    Last Post: 10-12-2010, 11:52 PM
  3. Wheel Popping in and out
    By 2000GrandPrixGTP in forum General Tech Discussion
    Last Post: 06-26-2010, 03:37 PM
  4. Popping In Reverse
    By Chmanzi in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-20-2010, 11:00 PM
  5. popping sound
    By flatblackgtp16 in forum General Tech Discussion
    Last Post: 07-30-2009, 12:15 AM
