Thread: 2001 Transmission question
Results 1 to 9 of 9
  1. #1 2001 Transmission question
    GT Level Member solidsnake1972's Avatar
    Oct 2011
    Plaster Rock New Brunswick
    A couple of months ago i lost 4th gear in my 2001 grand prix gt, i herd this is a common thing for these cars cause the gears are not hardened. I was reading somewhere gm started hardening the gears in the 2003 cars so what i was wondering will a 4 speed auto from a 2003 work in a 2001?
  2. #2 Re: 2001 Transmission question
    an 03 is specific to 03 only. An 04 would work. However..if you only lost 4th and want to replace only one part..in the car. It's not too bad to do it. Just takes a good amount of time.
  3. #3 Re: 2001 Transmission question
    Oct 2011
    So maybe change the forth clutch shaft and get a shift kit for it would be my best bet?
  4. #4 Re: 2001 Transmission question
    If it were mine and the only issue was no 4th, I'd lower the cradle and drivetrain a little. Pull the axle and side cover which means you drain the fluid. While draining fluid, put in a new filter and shift kit. Then pull the side cover. Do the 4th hub, which is easy if you use a picture with the notes in my pb account (Matt... insert Helpful pics/transmission, pic of bolts on trans and notes about which ones please). That would pretty much set you up.
  5. #5 Re: 2001 Transmission question
    Remove bolts 230, 231, 377, 805, 433, 434, 435, 436, 374, 379, 380, 384
  6. #6 Re: 2001 Transmission question
    Oct 2011
    Thanks for the help guy's, so this would be done from drivers side right. and can i leave the motor and tranny together?
  7. #7 Re: 2001 Transmission question
    Yup.. you support the body of the car. Support the drivetrain from above and pull the cradle. Then lower the drivetrain (biased to driver side if possible and then you can sneak the cover off the trans.
  8. #8 Re: 2001 Transmission question
    Oct 2011
    well i decided to get another trans but i was wondering if i get the 2004 trans will all the plugins from my 2001 harness fit into the 2004? and do i have to change anything to get the 04 to work in my 01?
  9. #9 Re: 2001 Transmission question
    From what I've heard..it works fine. Do a search on trannyman and I'm sure he's mentioned it before.
  1. 2001 GTP - replaced transmission or stock?
    By OldFart in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-01-2011, 11:50 AM
  2. 2001 GTP - Transmission fluid pressure at radiator?
    By RealtyCaffeine in forum General Tech Discussion
    Last Post: 11-14-2010, 06:21 PM
  3. 2005 transmission same as 2001?
    By mxzx in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-02-2009, 08:13 PM
  4. 2001 Grand Prix - Supercharger Question
    By nmaponte in forum Introductions/Noob Questions
    Last Post: 03-14-2009, 11:53 AM
