an 03 is specific to 03 only. An 04 would work. However..if you only lost 4th and want to replace only one part..in the car. It's not too bad to do it. Just takes a good amount of time.
If it were mine and the only issue was no 4th, I'd lower the cradle and drivetrain a little. Pull the axle and side cover which means you drain the fluid. While draining fluid, put in a new filter and shift kit. Then pull the side cover. Do the 4th hub, which is easy if you use a picture with the notes in my pb account (Matt... insert Helpful pics/transmission, pic of bolts on trans and notes about which ones please). That would pretty much set you up.
