Thread: Can't Get Drivers CV Shaft Out
Results 1 to 20 of 29
  1. #1 Can't Get Drivers CV Shaft Out
    GT Level Member grandamle91's Avatar
    Jun 2011
    Watertown, SD
    Is there a trick to getting the drivers side out, I've tried ply bar, bent my 4ft par. i've tried wrapping a rope around it and useing a tie down to pull on it. it moves about 2-3 cm.
    2000 GP GT 3.8 NA Stock Engine - Cat, EGR Deleted - K&N Cone - Pulstar Pulse Plug ad1h10 -6k HIDS- LEDS
  2. #2 Re: Can't Get Drivers CV Shaft Out
    Charles City, IA
    Hard and fast with a pry bar or if that fails slide hammer.
    SMGPFC Two Nipple General
  3. #3 Re: Can't Get Drivers CV Shaft Out
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Simultaneously pry with a crowbar near the transmission (not on the seal though), and hit it at the same time with a hammer or mallet. It's easier to do with 2 people.
  4. #4 Re: Can't Get Drivers CV Shaft Out
    It's a compression circlip that's holding it. If you put constant pressure, it's going to be super tight and likely going to fight the whole way at this point.
    You might be better off pulling the passenger side, popping the output shaft out of the diff and pulling the axle with the output shaft. Then you can hold the output and beat the heck out of the back of the inner cv cup with it out of the car.
  5. #5 Re: Can't Get Drivers CV Shaft Out
    Florida
    I always just used a crowbar and a quick yank popped it out.
    If that fails get under from the passenger side, with a pipe, or something long you cant hit the piss out of, and put that on the axle and one quick pop with a hammer does it.
  6. #6 Re: Can't Get Drivers CV Shaft Out
    PA
    As bill said, constant pulling isn't going to get it out easy. You need a quick and sharp force to compress the ring and let it come out. I use a pry bar like this:
    Works quite well most of the time.
    2001 GSE
  7. #7 Re: Can't Get Drivers CV Shaft Out
    Zef.. I got a 100%, easy every time solution.
    Great deal on GearWrench 82248 at ToolTopia.com
    This bad larry is the end all be all pry bar from what I've found. Took it up to my buddies shop (full time mechanic who has his own place) and he wanted to buy it after we did a motor swap.
  8. #8 Re: Can't Get Drivers CV Shaft Out
    Jun 2011
    Watertown, SD
  9. #9 Re: Can't Get Drivers CV Shaft Out
    Jun 2011
    Watertown, SD
    The other shaft is out too
  10. #10 Re: Can't Get Drivers CV Shaft Out
    you need to put a pry bar behind the cv shaft where it goes into the trans, and with your foot give it a sharp kick and pull it at the same time, its needs to be popped or it wont come out, a straight pull on it wont work.
  11. #11 Re: Can't Get Drivers CV Shaft Out
    Jun 2011
    Watertown, SD
    Ya i've done that, bent to pry bars, im going to try billboost why, keeping my fingers crossed
  12. #12 Re: Can't Get Drivers CV Shaft Out
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    That's insane!
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  13. #13 Re: Can't Get Drivers CV Shaft Out
    Jun 2011
    Watertown, SD
    Well i got the itch out but the whole shaft came with and only half of a clip. still can't get it to come of the shaft. I put it in a vice and beat the crap out of it and just a sore hand.
  14. #14 Re: Can't Get Drivers CV Shaft Out
    Charles City, IA
    The new axle should have a new clip on it.
  15. #15 Re: Can't Get Drivers CV Shaft Out
    Jun 2011
    Watertown, SD
    Any one have one, dont want to pay 130 for it
  16. #16 Re: Can't Get Drivers CV Shaft Out
    Charles City, IA
    your not replacing the axle?
  17. #17 Re: Can't Get Drivers CV Shaft Out
    Jun 2011
    Watertown, SD
    right now i have no choice, the damn cv shaft wont let go
  18. #18 Re: Can't Get Drivers CV Shaft Out
    Charles City, IA
    I thought you just said you got it out?
  19. #19 Re: Can't Get Drivers CV Shaft Out
    Jun 2011
    Watertown, SD
    the cv shaft and the shaft inside the trans
    ImageShack Album - 4 images
  20. #20 Re: Can't Get Drivers CV Shaft Out
    Hold the output shaft (part from inside the trans) in your left hand with the cv axle dangling to the floor. Now take your 3-5lb super BFH and hit the backside fo the cv cup. Repeatedly. Sooner or later it'll come out.
    And yeah..if you are charged, I think i have an output shaft laying around here.
    I've fought this battle. Keep on beating it. It will eventually come out. To reinstall that shaft. Gently slide it through the trans. When it bottoms out at the diff, turn it a little to feel it then give it one quick hit to seat it back into the diff.
    Now...if the axle is good on the driverside. then put the thing back in as a whole and don't worry about it til the axle goes bad.
  1. drivers side CV shaft
    By Jakegday in forum General Tech Discussion
    Last Post: 07-03-2010, 05:42 PM
  2. Cam Shaft Sensor
    By cmdeasy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2009, 03:51 AM
  3. Balance Shaft
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2008, 10:42 PM
  4. CV Shaft
    By webracin in forum Shops and Community Heroes
    Last Post: 04-15-2008, 01:38 AM
