Thread: How tuff is it to replace the 4th gear clutch hub?
Results 1 to 13 of 13
  1. #1 How tuff is it to replace the 4th gear clutch hub?
    Donating Users JDCMoney's Avatar
    Middleboro, Ma
    1998 GTP. I have the tranny out already, it had lost 4th gear and I replaced it with a used 2000 gtp tranny. Now the 2000's tranny is slipping in 1st like once a week. So I'm thinking I should just replace the clutch hub and pop that tranny back in. It always shifted great otherwise.
    So my question is "How tuff is it to replace that hub? Is there any literature on the web I could read on how to do it?"
    1998 Blue Raspberry Slushy Metallic GTP: The Daily currently has 185k+
    1989 Sierra:
    Weekend Warrior 1997 Regal GS: Stock For Sale 2000 GTP: Parts Car
  2. #2 Re: How tuff is it to replace the 4th gear clutch hub?
    Middleboro, Ma
    Trannyman any input?
    1989 Sierra:
  3. #3 Re: How tuff is it to replace the 4th gear clutch hub?
    It's cake.
    Pull the side cover gently (seal is reusable)
    Gently disconnect the electrical harness and remove it from the case
    Remove all the bolts on the channel plate lowest bolts you can see on the side where you opened it.
    Now remove the highest bolts (pump)
    There are 2-3 others that I can try to get a picture of tonight for you that need to come off. By not removing them all, you can leave the valve body and channel plate together. This keeps you from worrying about the checkballs and gaskets for those pieces. You only need the two channel plate gaskets.
    Then the hub is right on top. Lift your 4th clutches out and you have the hub in yoru hand. I have pics..but also a meeting in 1 minutes. Gotta jet.
    Check photobucket
    Billboost37
    Boosted
    Under transmission for an album.
  4. #4 Re: How tuff is it to replace the 4th gear clutch hub?
    London, Ontario
    It's cake.
    Check photobucket
    Billboost37
    Boosted
    Hi, Are you able to get some pictures to show which bolts need to be removed to get access? I have the tranny on the bench and I just need to replace the 4th gear hub... but if I can do it without having to open the valve body would be great.
    thanks
    Rob
  5. #5 Re: How tuff is it to replace the 4th gear clutch hub?
    Donating Users
    Nov 2009
    Shawnee, OK!
    Not to hijack but a quick question...
    Is this the fix for not going into 4th? My 00 gtp runs, shifts great except that a couple weeks ago, no more overdrive.
  6. #6 Re: How tuff is it to replace the 4th gear clutch hub?
    generally yes
  7. #7 Re: How tuff is it to replace the 4th gear clutch hub?
    London, Ontario
    Does anyone have a picture to show which bolts I have to remove without opening the valve body to replace the 4th gear hub?
    Thanks,
    Rob
  8. #8 Re: How tuff is it to replace the 4th gear clutch hub?
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    cake my ass. I would HIGHLY recommend taking to a shop and having them do it for you. You have to remove the valve body, channel plate, and a small portion of the clutch assembly. Not something i'd have a novice do. This isn't a brake job here..
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  9. #9 Re: How tuff is it to replace the 4th gear clutch hub?
    London, Ontario
    Thanks for the recommendation but I would rather attemp this myself. I am the type which will research something, attempt it, if I fail, try again. This is how I learn.
    Thanks again,
    though, I do plan to opening it all, but if billboost 37 can post a picture of which bolts I only require to remove?? This can save some time and maybe some headaches....
    But, if I can't get a picture showing, I will just go ahead and do it from the other threads on the interwebz regarding this.
  10. #10 Re: How tuff is it to replace the 4th gear clutch hub?
    Nov 2008
    I'm all for hands on, hell i've done countless motor/trans swaps just from learning as I go. automatic transmission isn't something i'd recommend doing unless you have a manual and some idea of what you're getting yourself into
  11. #11 Re: How tuff is it to replace the 4th gear clutch hub?
    SE Level Member tscheerer's Avatar
    missouri
    Thanks to this thread, and a couple others, I was able to replace the 4th clutch hub on our 99 GP. Took about 16hrs total over 3 days from pulling into garage to test drive, including pulling the pan and installing a shift kit. Did it without removing the trans by dropping the cradle on drivers side. For others considering it, research this site for tips and pics, that helped a lot.
    Thanks again!
  12. #12 Re: How tuff is it to replace the 4th gear clutch hub?
    Glad it helped.
  13. #13 Re: How tuff is it to replace the 4th gear clutch hub?
    USA
    Quote Originally Posted by JDCMoney View Post
    I would get an ATSG manual before going into it and for around 25 bucks, it would pay for itself.
  1. clutch or?
    By grand prix newb in forum 2.3L Quad 4 (L4)
    Last Post: 06-15-2010, 01:23 PM
  2. ac clutch
    By gtbeach in forum General Tech Discussion
    Last Post: 03-06-2009, 11:59 PM
  3. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
  4. 4th gear clutch hub install
    By CT Tech in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-06-2008, 11:03 PM
