can anyone make suggestions on how to change the ac clutch. I have borrowed the tool from autozone to change this. I am just not sure if it would be easier to go from the top or take off my tire and try to reach it thru there.
TY![]()
TY![]()
Be sure you're posting up in the correct area. That way you get the answers you need.
Sorry for the location of the thread.
I am still new to this forum. I was just trying to post an issue I need help with.
I will look around more before posting again.
Thanks
I have had alot of help on my car by just reading the posts on here. Alot of similar issues. I have 2 right now with my car. I don't want to post the next one in the wrong place so.........
Can you give some advice on where and how to post a new thread.
greatly appreciated!!!!
This one will be moved shortly. So if you can wait a cupple of hours then do that. If not post up in the general tech discussion. And we'll turn this one into a welcome thread.
Just kinda go on the home page and look at things. General tech is for things like... My a/c stopped working or I have an electrical problem...Engine is for engine problems or issues.Transmission is for transmission related and body or visual is for exterior or interior modifications or questions.
BTW TECH TIPS section is NOT to receive techincal tips but instead to give them. That seems to be a section that get's a lot of moved posts lately.
Hope you continue to enjoy the forum.
Again thanks for your help!!!!!!!!!!
I will keep doing some more looking. This forum has been very helpful and full of info.
It's great and I would recommend this forum to anyone that owns a GP.
TY
not sure how you can confuse "Introductions"......hmmmm....well, welcome to the site!!!
good luck to anyone who has to change this. What a pain in the a** becareful to check out the new clutch and sensor before putting the new one on. after getting the clutch changed noticed that the new sensor was cracked. Had to take everything back off and put the old sensor back on and replaced the other 2 new parts. after getting all put back together the ac clutch still would not engage. the bad sensor blew the diode.
