Ok so just an update, I hooked up my Snap-On Modis and went to the Command Gear section where it takes over the transmission basically and I just hit the ' Y ' button to shift. The one problem I found was, like someone previously said in this thread, I do not have 3rd gear, it's going straight from 2nd to OD explaining why it won't shift until 47MPH! AMAZING! When I tried to command it to go into the 3rd from 2nd the RPM does not change period when they definitely should drop and start 3rd gear but it doesn't, so thank you to the two or 3 that mentioned this particular solution.
