Thread: Transmission Shifting Hard After Swap
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21 Re: Transmission Shifting Hard After Swap
    Mar 2014
    Tucson
    Bill's usually right...
    I'm curious, what needed to be changed?
  2. #22 Re: Transmission Shifting Hard After Swap
    yup. one large mass import and your set
  3. #23 Re: Transmission Shifting Hard After Swap
    I started with HPT, bought a DHP along the way etc etc. There's benefits to each tuner and they are each a little incomplete/perfect on their own.
  4. #24 Re: Transmission Shifting Hard After Swap
    SE Level Member walkure's Avatar
    Aug 2011
    Puyallup, WA
    I believe that is was the pulses per revolution on the reluctor wheel. The way he explained it is that it helps the trans calculate input shaft speed versus output speed and if that is off the trans gets all confused.
  1. Shifting hard/jerking when shifting
    By Jonarin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-16-2016, 11:00 AM
  2. 97 gtp trand shifting hard from 2nd to 3rd gear.update!!!! shifts hard in every gear?
    By Doug 97 gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-12-2012, 12:18 PM
  3. Transmission shifting hard
    By bjm306 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-31-2012, 05:41 AM
  4. HELP!!! Transmission acting horrible, bucking, stuttering, grinding, shifting hard.
    By Lsick7 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-28-2009, 10:09 PM
  5. URGENT! Hard Shifting and Transmission Whine!!!
    By lvin4jc in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-21-2008, 08:46 PM
