Thread: Transmission Problem
Results 1 to 10 of 10
  1. #1 Transmission Problem
    Jan 2016
    Southwest Mn
    Alright guys, I have a question or opinions for you..I've got an 02 gtp and the vehicle will not move unless you put it in 1st and reverse works fine...after you get rolling around 20mph or so and put into drive the trans will run it up through the gears..fluid is nice and red and no smell of burning...any ideas?
  2. #2 Re: Transmission Problem
    busted forward band, rebuild time.
  3. #3 Re: Transmission Problem
    Jan 2016
    Southwest Mn
    Think a guy should do that or put a reman in?
  4. #4 Re: Transmission Problem
    Mar 2014
    Tucson
    Quote Originally Posted by gmtech99 View Post
    How handy are you? What's your time worth? For the cost of an ATSG manual, the band, and some other stuff, you could be rolling again on the original trans. It's a lot of work though.
  5. #5 Re: Transmission Problem
    either one of those will run you up to 2000.
    used swapped in at a shop 300 ish for a tranny 500 ish give or take for labor.
    comes down to are you willing to invest more then the cars book value or not.
  6. #6 Re: Transmission Problem
    Jan 2016
    Southwest Mn
    Swapped out trans with used one..now no 4th gear..not setting any codes..
  7. #7 Re: Transmission Problem
    Mar 2014
    Tucson
    Stripped splines on the 4th clutch hub. That's my bet.
  8. #8 Re: Transmission Problem
    Jan 2016
    Southwest Mn
    Oh man, Are you serious?
  9. #9 Re: Transmission Problem
    Mar 2014
    Tucson
    Yep. Fairly common on the older units.
  10. #10 Re: Transmission Problem
    Jan 2016
    Southwest Mn
    Well thanks for the input
  1. transmission problem
    By ericg1181 in forum General Tech Discussion
    Last Post: 09-07-2012, 09:13 PM
  2. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  3. Transmission Problem
    By cbeach in forum Introductions/Noob Questions
    Last Post: 12-30-2010, 08:23 PM
  4. Transmission problem
    By lhssnowman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-15-2009, 03:38 PM
  5. Odd transmission problem
    By ihartmacz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-30-2009, 12:43 AM
