Thread: Trans problems PLEASE HELP!
Results 1 to 20 of 25
  1. #1 Trans problems PLEASE HELP!
    Sep 2015
    us
    So a few months ago I bought my wife a 02 grand prix gt. We immediately had hard shifts after the car warmed up. So I did some research and came to the conclusion the Pressure Control Solenoid was bad. So I replaced it with an AC Delco pcs along with a new filter and fluid. Car had no problems for about a month ~1000 miles but now when the car warms up it shifts hard again and sometimes while at low speeds it jumps and bucks. So i checked the trans fluid it was low I added a quart and brought it back to proper levels I have not had the chance to test drive it but I am assuming it will still be having issues. I also have a CEL P0141 02 sensor heater circuit bank 1 sensor 2. Not sure if that is related but any advice or knowledge would be greatly appreciated thanks guys.
  2. #2 Re: Trans problems PLEASE HELP!
    Can your scanner read trans code though?
    You may have a P1811 or P0730 or P0742 present.
    http://tripleedgeperformance.com/4T6...-Problems.html
  3. #3 Re: Trans problems PLEASE HELP!
    Sep 2015
    us
    No unfortunately it can't read trans codes.
  4. #4 Re: Trans problems PLEASE HELP!
    May 2012
    Where winter never ends
    Go get those read, will help you out immensely.
    2000 Regal - Winter Beater
  5. #5 Re: Trans problems PLEASE HELP!
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    also, keep in mind, some trans codes wont stay in the computer after a key cycle. needs to be scanned before the key is turned off after the condition occurs.
  6. #6 Re: Trans problems PLEASE HELP!
    Sep 2015
    us
    Do shops usually charge to scan codes?
  7. #7 Re: Trans problems PLEASE HELP!
    most scanners will show tranny codes, all P codes show up, tranny codes are P codes.
  8. #8 Re: Trans problems PLEASE HELP!
    i got this cheap ass scanner. works fine.
    http://www.ebay.com/itm/Car-Diagnost...141678&vxp=mtr
  9. #9 Re: Trans problems PLEASE HELP!
    Mar 2014
    Tucson
    Kinda off topic, but I've been wondering... Will the torque app / ELM237 read trans codes?
  10. #10 Re: Trans problems PLEASE HELP!
    it also reads all p codes as far as i can tell. it also clears codes, but is super slow to deal with for code reading.
  11. #11 Re: Trans problems PLEASE HELP!
    May 2012
    ELM327 has the ability, its the software behind the scanner. The communication protocol is J1850 VPW. Its a standard, what matters is the software behind the hardware. Torque may do it, though idk, easiest way is to try or drive to an autoparts store (Autozone, O'rilies) walk in and say can I scan my car. They will hand you a scanner and say go have fun.
  12. #12 Re: Trans problems PLEASE HELP!
    Mar 2014
    Tucson
    Quote Originally Posted by ADecker View Post
    Where's ATuner....?
  13. #13 Re: Trans problems PLEASE HELP!
    Sep 2015
    us
    The scanner I have uses the torque app not really sure if it reads trans codes
  14. #14 Re: Trans problems PLEASE HELP!
    Sep 2015
    us
    If it was low on trans fluid could that possibly cause a long shift and trigger that code making it shift hard or is that not likely?
  15. #15 Re: Trans problems PLEASE HELP!
    Your best bet is to put transgo shift kit into it. that'll make it shift faster and it won't see the long shift times. A couple of very respected trans builders aka Tripleedge have mentioned that if you follow GM's standard clutch setup you could have so much slop as to cause the issue. Drop in a shift kit and poof..it'll take care of the issue for $45 plus fluid.
  16. #16 Re: Trans problems PLEASE HELP!
    Sep 2015
    us
    Yeah I have heard good things about the transgo kits. That might be the path I take because replacing that pcs was kind of a pain and that doesn't seem to be the issue.
  17. #17 Re: Trans problems PLEASE HELP!
    Likely it's the amount of slop in the clutch packs.. which I was eluding to in my earlier post.
    Since you aren't going to rebuild and could essentially fix it for small dollars...it's the best thing.
  18. #18 Re: Trans problems PLEASE HELP!
    Sep 2015
    us
    I see what kind of life should I expect out of it after I install a shift kit before it completely craps out on me.
  19. #19 Re: Trans problems PLEASE HELP!
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by ummandyea View Post
    I installed my TransGo kit almost 5 years ago (100,000 KM). Still going strong, for a sloppy a$$ hi-mileage tranny. LOL
    You could last just as long, or longer, or less. It is a crap-shoot depending on what really is wrong inside the tranny.
    Read this too if you haven't already.... http://www.grandprixforums.net/threa...Shift-Solution
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  20. #20 Re: Trans problems PLEASE HELP!
    If you tell us rpm, torque, thoughts of the person driving, temperature inside the trans and exterior for every mile driven.. we might be able to get some kind of formula that estimates how much longer it'll live.
    The kit will stop the bang shifts and code, after that.. you are unfortunately at the mercy of the transmission gods.
  1. TK trans problems
    By SilentKillzr in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-09-2013, 10:56 PM
  2. Trans Problems...
    By gagt3100 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-25-2012, 11:20 PM
  3. GTP Trans problems
    By kiefer316 in forum General Tech Discussion
    Last Post: 03-14-2011, 10:29 AM
  4. trans problems
    By carl612 in forum Forum Bugs/Suggestions
    Last Post: 07-31-2010, 09:03 PM
  5. Trans problems.
    By my97gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-07-2008, 07:24 AM
