Your best bet is to put transgo shift kit into it. that'll make it shift faster and it won't see the long shift times. A couple of very respected trans builders aka Tripleedge have mentioned that if you follow GM's standard clutch setup you could have so much slop as to cause the issue. Drop in a shift kit and poof..it'll take care of the issue for $45 plus fluid.
