Thread: Diff Swap Question
Results 1 to 4 of 4
  1. #1 Diff Swap Question
    Nov 2015
    Derby KS
    Ok I have a 4t65e in a 1999 grand prix that i am putting a supercharged engine into, I also have a 4t60e HD trans out of a 96 supercharged riviera, as far as i know this is a rare option on 96 supercharged GM models only, my question is can i use the diff, the cover and right axle shaft out of the riviera for my grand prix? Also should I use the torque converter?
  2. #2 Re: Diff Swap Question
    Honestly it's not even worth the swap.
    I'd rather just keep the 3.29 gearing in the GT, we are only talking a slightly stronger diff in the supercharged cars. Not enough to make a huge difference, you likely won't smoke the diff anyway when the transmission blows up. The input shaft or massive slipping happen far more often.
  3. #3 Re: Diff Swap Question
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Yeah, the diff is rarely what ends up getting destroyed. I'd be more worried about the input shaft snapping on 3-1 downshifts. The L36 converter is lighter and is a bit looser, I'd use that if you have new hardware to swap flexplates. Or flip a coin and reuse the old bolts with red loctite.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  4. #4 Re: Diff Swap Question
    Nov 2015
    Derby KS
    Alright thanks for the input, i haven't heard from anyone i know about the diff going bad anyway. The trans in my grand prix was already rebuilt before i got it, i think it has less than 50k miles on it but not sure and i probably will reuse the converter that is in it already.
  1. Tranny slip after diff swap
    By TimMcCallum in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-02-2014, 06:12 AM
  2. 4t60e hd diff swap
    Last Post: 04-08-2014, 09:18 AM
  3. hd diff swap
    By grannycar in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-30-2011, 11:23 PM
