Thread: HELP!! Low beams not working
Results 1 to 16 of 16
2coolit HELP!! Low beams not working 05-16-2013, 09:16 AM
BillBoost37 Re: HELP!! Low beams not... 05-16-2013, 09:20 AM
2coolit Re: HELP!! Low beams not... 05-16-2013, 09:28 AM
BillBoost37 Re: HELP!! Low beams not... 05-16-2013, 09:32 AM
2coolit Re: HELP!! Low beams not... 05-16-2013, 09:37 AM
BillBoost37 Re: HELP!! Low beams not... 05-16-2013, 09:39 AM
2coolit Re: HELP!! Low beams not... 05-16-2013, 09:51 AM
02NavyBlue Re: HELP!! Low beams not... 05-16-2013, 10:02 AM
BillBoost37 Re: HELP!! Low beams not... 05-16-2013, 09:54 AM
2coolit Re: HELP!! Low beams not... 05-16-2013, 09:54 AM
02NavyBlue Re: HELP!! Low beams not... 05-16-2013, 09:56 AM
BillBoost37 Re: HELP!! Low beams not... 05-16-2013, 09:57 AM
2coolit Re: HELP!! Low beams not... 05-16-2013, 09:59 AM
2coolit Re: HELP!! Low beams not... 05-16-2013, 10:08 AM
2coolit Re: HELP!! Low beams not... 05-22-2013, 09:57 AM
SlowNA06 Re: HELP!! Low beams not... 05-22-2013, 10:32 AM
  1. #1 HELP!! Low beams not working
    Jan 2013
    Kansas
    Two days ago I hooked up the LED strips I had in my footwell to my gear shifter light so they would be on whenever the headlights where on, so now yesterday I noticed my low beams wherent working. Both of them. I checked the fuses, the bulbs didn't look burned out, so I figured It had something so do with the LEDs so I cut them off the wiring for them and they still don't work. The high beams work perfectly just the low beams don't. Please help
  2. #2 Re: HELP!! Low beams not working
    The wiring you did to the shifter light is the interior circuit, this is seperate from the exterior low beams.
    When you say you checked the fuses etc. Did you check the circuit breaker for the headlights? Have you checked the multifunction switch and have you checked that your headlights aren't getting grounded?
  3. #3 Re: HELP!! Low beams not working
    Jan 2013
    Kansas
    no I haven't... circuit breaker would be in the fuse box right? and my friends said it might be the multifunction switch... how do you replace one? how would I check if they are grounded? sorry for the questions, im a 16 year old....
  4. #4 Re: HELP!! Low beams not working
    It's all good.. all you have to do is tell us what level you are at and we can give you guidance on where to go or how to do stuff.
    So you are 16 and sound like you don't have much experience with this stuff yet.
    Pop the hood and look behind the headlights. There's a metal piece that sticks out..it can cut a wire if the headlight has gotten hit or has a bad bracket. Take a look at the wiring, see any obivous issues?
    The circuit breaker location ....what do you have for a car? 97-03 is in the glove box fuse location.
    Multifunction.. at that point, you are using a multimeter, have any experience with one?
  5. #5 Re: HELP!! Low beams not working
    Jan 2013
    Kansas
    yeah pretty much no experience... first car too. I'll check here soon and get back with you. its a 2008 GP base. ive kinda ran one, if not my dad could probably help me later. But what do I do with one? what wires do I check?
  6. #6 Re: HELP!! Low beams not working
    Well..that required knowing which year you had. I don't have that schematic in my Photobucket currently. But I'm sure someone here does have it and can post it. So by you and I chatting about it and me saying "someone please post the headlight schematic at the column/mulitfunction" that should get us a diagram. From there we can all talk about what/how to test.
  7. #7 Re: HELP!! Low beams not working
    Jan 2013
    Kansas
    alright ill try help out on that. I took my headlights off and no visible problems everything seemed in order.
  8. #8 Re: HELP!! Low beams not working
    Dec 2012
    Where 4T65E's were born
    No problem. It's a big pic, hope it displays fine for you guys. It looks good here.
    Sold.
  9. #9 Re: HELP!! Low beams not working
    Cool... step 1 complete and good.
    Next up.. we could use a schematic.
  10. #10 Re: HELP!! Low beams not working
    Jan 2013
    Kansas
    ill try google....
  11. #11 Re: HELP!! Low beams not working
    Dec 2012
    Sold.
  12. #12 Re: HELP!! Low beams not working
    Sweet..thanks NavyBlue
  13. #13 Re: HELP!! Low beams not working
    Jan 2013
    Kansas
    or that works, thank you NavyBlue
  14. #14 Re: HELP!! Low beams not working
    Jan 2013
    Kansas
    Yep its perfect. take up most of my screen
  15. #15 Re: HELP!! Low beams not working
    Jan 2013
    Kansas
    Never mind... Thank goodness it was just a headlight relay.... $43! better then buying a brand new dimmer switch... Now I don't want to take the risk and hook my LED's up again... cause I don't wanna waste another $43 dollars on something I could prevent
  16. #16 Re: HELP!! Low beams not working
    Pennsylvania
    Gahh. Wish I saw this sooner. Having a 2008 was the clue to solving this - that relay is a jerkface doodoohead from 2006-2008. Also, they're $17 shipped on ebay.
  1. Projector Hi-Beams
    By DanPrixGTP in forum Visual/Body Modifications
    Last Post: 05-18-2013, 07:27 AM
  2. Low beams not working.
    By Focusin in forum General Tech Discussion
    Last Post: 04-24-2013, 12:07 PM
  3. Hi beams and low beams at the same time?
    By PurpleGuy in forum Audio, Security & Visual Electronics
    Last Post: 06-06-2012, 12:38 AM
  4. No Low Beams, Please Help
    By Andrew Nelson in forum General Tech Discussion
    Last Post: 06-01-2012, 05:41 AM
  5. My DRLs & Low Beams Are not working, high beam work
    By FlaminWhite97GTP in forum Audio, Security & Visual Electronics
    Last Post: 01-18-2010, 01:26 PM
