Thread: Projector retrofit completed, light output very bad...
Results 1 to 8 of 8
  1. #1 Projector retrofit completed, light output very bad...
    May 2011
    wisconsin
    Just retrofitted morimoto mini h1 projectors from theretrofitsource.com into some new stock housings. Ddm hids 6k bulbs. Everything is aimed prefect and it looks amazing with my led amber halos BUT ther light output is very bad... Things i modded are, step delete (straight cutoff) painted the cutoff sheild red and put 1 spacer in between the bowl and the cutoff shield to have a bluer cutoff. while driving I can't even see the cutoff on things and while driving through town it doesn't even look like my lights are on... My fogs are brighter... Any ideas why my light output sucks balls? Really considering just putting my stock housings back in and blinding everyone..
  2. #2 Re: Projector retrofit completed, light output very bad...
    Brightening up your day. Koniig's Avatar
    Jun 2010
    Illinois.
    It has the be the way your bulb is placed. Check the fitment of the bulb in the back of the housing and make sure it's aligned properly.
  3. #3 Re: Projector retrofit completed, light output very bad...
    Pictures of how you did it can help.
  4. #4 Re: Projector retrofit completed, light output very bad...
    May 2011
    wisconsin
    Theres only one was the bulb can possible sit in the projector
  5. #5 Re: Projector retrofit completed, light output very bad...
    GTP Level Member
    springfield IL
    Pics also op!!!, ASAP
  6. #6 Re: Projector retrofit completed, light output very bad...
    GTP Level Member
    springfield IL
    Yeah this is exactly why I just stuck with my stock housings, very happy with them
  7. #7 Re: Projector retrofit completed, light output very bad...
    May 2011
    wisconsin
    Tried uploading pictures but kept saying I exceeded the limits...
  8. #8 Re: Projector retrofit completed, light output very bad...
    upload them to a host somewhere else, then link with [img] tags.
  1. 04+ Projector Retrofit
    By Koniig in forum Visual/Body Modifications
    Last Post: 07-10-2017, 03:02 PM
  2. Retrofit projector help please
    By szalajka05 in forum Visual/Body Modifications
    Last Post: 04-21-2012, 06:24 AM
  3. My Projector Retrofit
    By Dawings33 in forum 04+ Specifics
    Last Post: 09-06-2011, 09:49 PM
  4. Projector retrofit
    By rocket69GTP in forum Visual/Body Modifications
    Last Post: 04-17-2011, 12:46 PM
  5. Let there be LIGHT! (Morimoto projector retrofit)
    By BackInBlack in forum Visual/Body Modifications
    Last Post: 02-09-2011, 11:03 PM
