Thread: condesation in new headlight housings
Results 1 to 13 of 13
  1. #1 condesation in new headlight housings
    Mar 2012
    Minnesota
    Hey, as posted above does anyone have any fixes for condensation in new headlight housings?
  2. #2 Re: condesation in new headlight housings
    GTX Level Member mofford12's Avatar
    Nov 2012
    Cincinnati
    you COULD drill small hole for the water to drain out of the headlight lol.. obviously on the bottom of the housing.. jus not where you can see it
  3. #3 Re: condesation in new headlight housings
    Mar 2012
    Minnesota
    would that help get the condensation off the glass?
  4. #4 Re: condesation in new headlight housings
    Aug 2011
    'Merica
    it should.
  5. #5 Re: condesation in new headlight housings
    Nov 2012
    Cincinnati
    yea it should.. ive done it an its worked
  6. #6 Re: condesation in new headlight housings
    Aug 2011
    'Merica
    i have done it to my tail light and no condensation
  7. #7 Re: condesation in new headlight housings
    Mar 2012
    Minnesota
    okay, so on the bottom of the housing or where works best?
  8. #8 Re: condesation in new headlight housings
    Mar 2012
    Minnesota
    okay sweet, thanks, like drill a 1/8 inch hole or something?
  9. #9 Re: condesation in new headlight housings
    Nov 2012
    Cincinnati
    yea that will do.. but dont do it on the front where you can see it.. pull the light out an drill the bottom of the light..{the black area} lol
  10. #10 Re: condesation in new headlight housings
    I used like a 7/62nd size bit.
    Dont make it too big.
  11. #11 Re: condesation in new headlight housings
    Mar 2012
    Minnesota
    okay, ill use a 7/64ths then
  12. #12 Re: condesation in new headlight housings
    Aug 2011
    'Merica
    ^^this. holes don't need to be huge, just enough to let the condensation out
  13. #13 Re: condesation in new headlight housings
    I did it right in the corner on the bottom when I did it on my corner lights.
    Like left front corner area, you can see the holes buy only if you are really looking fro them.
