jteske: im not sure what your asking, but my gauges are pretty clear and bright if thats what your asking.
c
ameron: no the switches were a little more involved, i pulled the switches apart and disassembled them. On the bottom of each led youll see two posts that theyre soldered to. I plugged the switches in to the harness when they were still torn apart and used a voltmeter to see which pin supplied the voltage when the lights were switched on. Next i desoldered the old leds, set up my new resistor, and led setup, and glued them in place. after i found where they would fit and everything would go back together i ran the power side of the led to the posative pin on the switch connector that you checked power for earlier, and the neg. side of the led to the other spot on the switch. I will be doing the other switches tommorow if radioshack got more leds in, and ill take some pictures to better describe it
