Thread: started changing the interor lighting to leds, and cleaned up the trunk a bit
Results 1 to 20 of 22
  1. #1 Re: started changing the interor lighting to leds, and cleaned up the trunk a bit
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    Quote Originally Posted by Jteske88 View Post
    i did that on my shifter selecter by the actually shifter, when there of does it look clear to you?
    was it hard to do that to the shift selector
  2. #2 Re: started changing the interor lighting to leds, and cleaned up the trunk a bit
    GT Level Member nicks98gtp's Avatar
    michigan
    and doug, it should be a plug and play twist lock connector on the shift selector, so you should be able to use one of the same bulbs the cluster used if you had some left over ( i think theyre the same size bulb but not posative since i havent done the shift selector yet)
    98 Gtp, ported s/c, fully rebuilt motor .20 oversized pistons, rebuilt trans, zzp pcm,more mods to come
  3. #3 Re: started changing the interor lighting to leds, and cleaned up the trunk a bit
    Yoga city
    Quote Originally Posted by Doug 97 gtp View Post
    no the letters do have red on the back so you have to take it out and clean off the red. watch out cause if you go through to much you will ruin what it is suppose to look like
  1. Trunk Lighting????
    By nikkigpgt00 in forum Audio, Security & Visual Electronics
    Last Post: 01-19-2013, 08:58 PM
  2. Cleaned my TB and MAF...
    By armyrebel03 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2011, 03:24 PM
  3. all cleaned up!
    By kuntzie in forum Visual/Body Modifications
    Last Post: 05-22-2010, 01:03 PM
  4. Cleaned up (on going)
    By stlmo_gtp in forum Visual/Body Modifications
    Last Post: 10-29-2008, 04:20 PM
  5. Changing LEDs in your angel eyes [*]
    By Preotic in forum How To Write-Ups/Tech Tips
    Last Post: 04-11-2008, 11:05 PM
