Thread: Help with HID/ headlights
Results 1 to 20 of 26
  1. #1 Re: Help with HID/ headlights
    Florida
    Thank you for the help what bulb did you end up putting in the fogs? and where do people hide the ballasts for the HID kits? also if i order from ddmtuning do i need the HID harness, Error eliminator, and adapter cable? this question goes for both the headlights and fogs i am using the stock fog light housing and also i am getting a set of dashzracing headlights(Headlight link) thank you for any input
  2. #2 Re: Help with HID/ headlights
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    Quote Originally Posted by Iceroyal View Post
    The fog light gets replaced with an HID 880 bulb. I hid my ballasts in the fenders after doing a bit of elongating of some of the wires on the harness it came with. I have the harness for the headlights and not the fog lamps. Nothing else is needed at all, I recommend getting the harness, just to make sure your not putting any added strain on the GP's stock wiring, although I'm sure you would be fine without it. As for which bulb to get for the headlights i am NOT positive for those headlamps but i believe it is the H1 bulb. Installation is really self explanatory once you lay everything out. I can take a few pictures of where my ballasts are mounted but it won't be for about a week. Let me know if you have any more questions! Oh, and here is a link to a few of my pictures with the HID's installed. Pictures by chamilton89 - Photobucket
    Infinity all around.
  3. #3 Re: Help with HID/ headlights
    As it seems, I am an idiot. After looking at the link you left me for your projector headlights, it says right in there the low beams have an H3 bulb, not H1 as I said before. Hope that helps.
  4. #4 Re: Help with HID/ headlights
    Florida
    Thank you for the help again. So I definitely don't need that error eliminator ? Sorry first time doing them so wanna get it right.
  5. #5 Re: Help with HID/ headlights
    Nope. Don't have any issues at all without the error elemonator. I have the dogs running of the factory harness just plugged right in and my headlights are on a harness. Also, wanted to make sure you remove your drl relay before you install your HIDs. The drls will play havoc with your HIDs if you don't!
  1. Headlights?
    By jimmywindle2012 in forum Introductions/Noob Questions
    Last Post: 02-17-2011, 11:26 PM
  2. New headlights
    By ERballa238 in forum Introductions/Noob Questions
    Last Post: 02-16-2011, 03:43 AM
  3. Headlights
    By trapguy50 in forum General Tech Discussion
    Last Post: 10-15-2009, 09:13 AM
  4. new headlights!!!!!!
    By 99gpse in forum Visual/Body Modifications
    Last Post: 06-02-2009, 08:17 AM
