Thread: rust questions
Results 1 to 20 of 22
  1. #1 rust questions
    Jun 2011
    canton ohio
    Hey im new here and have bought s 97 gtp and has a list of problems I will start with rust. Rockers are gone and its starting to make its way up the jam. Also the driver quaurter panel is bad. But shock towers are solid and so is most of floor also gas lines are leaking and runs rough at 1000 rpm. But I believe that goes on another post.
  2. #2 Re: rust questions
    Omaha, NE
    I didn't see a question mark in that entire post...What were your questions?
  3. #3 Re: rust questions
    Waukesha, WI
    buy replacement rockers and splice in, patch quarter panel? what are you looking for there boss
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  4. #4 Re: rust questions
    Jun 2011
    canton ohio
    Ohh sorry any body know about how much im looking at spending is it worth fixing or should I drive it til the wheels fall off?
  5. #5 Re: rust questions
    Waukesha, WI
    its a 97 grand prix, if your in love with it spend somemoney get the rust fixed and undercoated, if your wanting to upgrade in a few years, drive it till the wheels fall off
    RayRay
    92 Turbo miata
    02 lexus is300
  6. #6 Re: rust questions
    Jun 2011
    canton ohio
    Oh and where the rockers should be is empty space part of the floor is rusted to. The the the rockers atach to are gone also
  7. #7 Re: rust questions
    Jun 2011
    canton ohio
    Well the inside is perfect almost. The engine is fairly clean all the issues with the car are rust related and im wondering am I looking at a few hundred or thousand to make it right?
  8. #8 Re: rust questions
    London Ont, Canada
    drive it until the wheels fall off, save the repair money on a newer less rusty GP
  9. #9 Re: rust questions
    Delaware, OH
    Just think of the rust as Gods weight strpping mod.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  10. #10 Re: rust questions
    Jun 2011
    canton ohio
    I like the way you think benner but like I said im looking more for a repair cost
  11. #11 Re: rust questions
    GT Level Member Tea Time's Avatar
    New Brunswick
    couple thousand to have it done right by someone else....u'll need to paint it too with that quarter panel work.
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  12. #12 Re: rust questions
    Delaware, OH
    Honestly you may be able to find a vocational school that'll do the work for cheap (possibly the price of supplies). It's a learning experience for students but the teachers also make sure the work is done right (unless it's some hack school)
    No More GTP for me.
  13. #13 Re: rust questions
    Waukesha, WI
    generally voc schools dont like rust repair, as its filler work at most shops,
    RayRay
    92 Turbo miata
    02 lexus is300
  14. #14 Re: rust questions
    Jun 2011
    canton ohio
    Thousands???? Really I can spray it later I just need metal replaced.
  15. #15 Re: rust questions
    SE Level Member LePrix's Avatar
    May 2011
    Ottawa, ON
    My old LeSabre had just surface rust on the lower fender/panel, the cheapest estimate I could find was $450 and thats just sanding and painting, the shops I trust wanted $1000+. Now you actually have rusted through so I don't know. I never ended up fixing the rust on the Buick and 4 months later I got a rear main seak oil leak, $1500 repair, so I chucked the car.
    In my opinion, unless you know for certain that the car is mechanically strong or at least a valuable resale, I would not do expensive body work. There are plenty of rust free cars in the junkyard, and i'm sure some of them had expensive body work done...
  16. #16 Re: rust questions
    Jun 2011
    canton ohio
    What about a way to keep it from rusting any further
  17. #17 Re: rust questions
    Waukesha, WI
    POR15, or naval jelly boss
    RayRay
    92 Turbo miata
    02 lexus is300
  18. #18 Re: rust questions
    If the rust is getting into the door jams,door sills, or pillar its not worth fixing.... Thats why I'm not doing it on mine. Ray saw my car a couple weeks ago and I trust his judgment. Maaco had quoted me close to a grand/slightly over that to fix the rust and that was with me providing the parts, plus having my car at least a week.... Other shops in the area (ones that are real professionals and that I've personally seen them put a car back together that had been severely damaged ) wanted up to 2500 or more.
    The best advice I can give is drive it from point A to point B (wheels fall off) or try finding another GP shell that has little to no rust and transferring all your stuff to that shell IE engine,interior and such. Last choice would be save your money and buy something newer...
    Snorlax strikes again.
  19. #19 Re: rust questions
    Jun 2011
    canton ohio
    Well its not in the door sills or pillars and just to bottom hinges on door. It needs rockers ladders it whatever u call them that the rockers attach to and a quarter panel other than that strut towers are solid interior is pretty nice. Sub frame is solid. Steering is tight.
  20. #20 Re: rust questions
    New Brunswick
    got some pics?
    '97 GTP - Project
  1. RUST!
    By Taz Magister in forum Brakes/Suspension/Chassis
    Last Post: 03-17-2011, 01:09 PM
  2. Underbody rust
    By tdm571 in forum General Tech Discussion
    Last Post: 02-21-2011, 09:39 AM
  3. Anyway to get the rust out
    By grandprix17 in forum Visual/Body Modifications
    Last Post: 01-07-2010, 01:42 AM
  4. Ive got rust
    By MikeZirpola in forum Visual/Body Modifications
    Last Post: 09-24-2009, 01:08 PM
  5. Rocker rust
    By MichEE in forum Visual/Body Modifications
    Last Post: 09-10-2008, 11:28 AM
